Barcus-Berry Standard Preamp Model 1330 (OPAMP VERSION)
Re: Barcus-Berry Standard Preamp Model 1330 (OPAMP VERSION)
Postby Manfred » 06 Jan 2020, 21:01
roseblood11 wrote:Is there really no better solution than using transformers as inductors?
4700uH inductors are avaliable on ebay.
Now what is correct, 4.7H, 500mH transformer, 4700uH = 4.7mH? :?
Manfred
Has thanked: 1083 times
Have thanks: 687 times
Postby soulsonic » 06 Jan 2020, 21:11
! ! ! ! Good catch! :lol:
Has thanked: 73 times
Have thanks: 296 times
Postby Manfred » 07 Jan 2020, 20:37
One more Question.
What is the pin spacing of the potentiometers?
Manfred
Postby Manfred » 08 Jan 2020, 00:02
Hi Soulsonic,
to create this layout i made a template from the photos and had the problem that when the opamp pinout was right the pads for the potentiometers had a distance of 1/4".
Is this true or is the real distance 1/5", if necessary I will adjust the layout.
Manfred
Postby soulsonic » 08 Jan 2020, 00:53
The spacing I measured is 1/4". The original pots are the larger size CTS branded ones, like one usually sees in older guitars and amps. I believe they are approximately 1" diameter.
Postby Manfred » 08 Jan 2020, 02:47
soulsonic wrote:The spacing I measured is 1/4". The original pots are the larger size CTS branded ones, like one usually sees in older guitars and amps. I believe they are approximately 1" diameter.
Ready to print PDF-files:
BarcusBerryStdPreAmpModel1330_ComponentSide.pdf
BarcusBerryStdPreAmpModel1330_SolderSide.pdf
SprintLayout 6.0 File:
BarcusBerryStdPreAmpModel1330.zip
Manfred
Previous
Users browsing this forum: efirre and 3 guests
