California Amps - SET5 Head - Schematic
Postby culturejam » 13 Feb 2020, 03:09
This is a cheap little 5W chinese head I picked up in 2018. It was $99 shipped! The seller was even nice enough to send me the factory schematic on request. :D (attached)
Here's the specs:
• 5 watts via 1x EL84 and 1x 12AX7 (Chinese tubes, of course)
• Treble, Bass, and Volume controls
• 1W and 0.1W attenuation modes (slide switches on rear)
• 8 and 16 ohm outputs
Not a crazy complex amp, but definitely not just another Valve Jr variant. It's definitely worth $99 at the very least.
For this message the author culturejam has received thanks: 5
287m (13 Feb 2020, 15:34), bajaman (13 Feb 2020, 04:41), BuryMeInSmoke (18 Feb 2020, 00:43), deltafred (13 Feb 2020, 09:41), HENK (13 Feb 2020, 12:00)
culturejam
Has thanked: 481 times
Have thanks: 595 times
Return to Amplifiers
