Fulltone - Supa-Trem
Re: Fulltone - Supa-Trem
Postby gtrplaya101 » 04 Nov 2008, 14:04
Cool Stuff!! :applause:
gtrplaya101
Postby Barcode » 09 Nov 2008, 23:15
I'm afraid it is going to be a while before I can work up this schem, work is getting crazy right now.
Barcode
Have thanks: 35 times
Postby mistral » 03 May 2009, 20:40
HI
Please, someone can post the supa-trem schematic?
mistral
Postby audioguy » 25 May 2009, 04:24
Yeah Im missing a good trem... I've tried a few, but Im still lookin for the 'one'.
audioguy
Has thanked: 24 times
Have thanks: 6 times
Postby Roa » 15 Jul 2009, 23:05
Looking for the supa trem schematics, anyone has them????? :scratch:
Roa
Have thanks: 2 times
Postby Rocket Roll » 20 Sep 2009, 12:42
Barcode wrote:Image
I think that R1 should be 1K5, not 7K5. Demeter Tremulator has 1K there (R17) and a 5K trimmer in series, and Baja Trembulator has 1K there and a 10K trimmer in series. Photos are a little blurry, but that resistor looks like brown-green-red one here:
Rocket Roll
Have thanks: 34 times
Postby Rocket Roll » 20 Sep 2009, 13:35
Also, R14 looks like 8K2 (the same as in Demeter - R4).
Rocket Roll
Postby Barcode » 21 Sep 2009, 16:14
If that is the case, then the parts values must not be that critical, as I have now built about 10 of these with the values listed and they all work great!
Barcode
Postby Rocket Roll » 04 Oct 2009, 01:09
Barcode wrote:If that is the case, then the parts values must not be that critical...
I'd say you're right. Here's how mine sounds (with those changes & trimmers adjusted to my liking):
http://www.box.net/shared/1c3h6d4org
Rocket Roll
Postby my7of9 » 04 Oct 2009, 02:05
That sounds excellent!!! :applause:
my7of9
Have thanks: 12 times
Postby mistral » 06 Oct 2009, 12:33
Barcode wrote:Okay, worked up a new layout slightly based on fuller's. The values are what i used when i made my clone, and the pads are there for all the different switches, but i didn't put them in my build. The rate pot totally covers all usable speeds for me, so no double/half switch needed, and I used an external pot for the hard/soft trim pot instead of installing the switch. I haven't test this specific layout yet, but i've node checked and it isn't far off the original, so it should be good. funny thing is i haven't had time to work up a schem, so i'm hoping ag or someone can finish out the project with a schem.
What´s the pcb dimensions, please
mistral
Postby mistral » 15 Nov 2009, 20:54
Hi
sorry for my poor english
I´ve building the dull bone koopa gem and i have some troubles
I,ve building the footswitch soft/hard, ok
I,ve building the footswitch dual potentiometer 1M/500k, ok
The sound is very very crunch, distortion, and the rate led lighting but not intermittent.
The ics are tl071 and tl072. Before, are the originals from he supatrem, tl061, lf442 and other and the distortion have been minor.
What´s the problem?. take me a hand, please
Regards
mistral
Postby mistral » 17 Nov 2009, 09:32
Hi, i´ve discovered the problem, connected traces.
it sounds like a melody
fantastic effect, fantastic pcb thanks for it
Regards
mistral
Postby mistral » 11 Dec 2009, 13:02
mistral
Postby PCN » 18 Oct 2011, 23:39
Have the capacitors of 1mF and 2,2mF to be NP? Is there a reason to Mike Fuller prefer NP?
PCN
Postby gilmour_pugliese » 26 Jan 2012, 18:52
About the speed pot: would be better a log or a linear type? :hmmm:
gilmour_pugliese
Postby friend321 » 06 Jun 2012, 15:39
i am interessted in this question too, about the NP capacitors
and i've got a ticking problem even, when the unit is turned off. did anyone build this fully working without any ticking noises? if so, what special components did you use?
friend321
Postby Dirk_Hendrik » 06 Jun 2012, 16:45
friend321 wrote:iand i've got a ticking problem even, when the unit is turned off
Welcome in the great world of the "blessings" of true bypass. ;-)
Has thanked: 256 times
Have thanks: 1046 times
Postby friend321 » 06 Jun 2012, 17:18
.. no it should be possible to build this with true bypass like fulltone does. did you built this trem?
friend321
Postby rs » 07 Jun 2012, 00:57
Hi there, i've built it and it works fine. At first i've had some ticking noises too but then i realise the original has the rate pot wired with shielded cable, i swaped mine and put in some shielded wire too, and that stopped the ticking .
Hope it helps.
rs
Has thanked: 102 times
Have thanks: 7 times
Users browsing this forum: jovesdies, jt and 7 guests
