Fulltone - Supa-Trem
Re: Fulltone - Supa-Trem
Postby friend321 » 07 Jun 2012, 10:23
oh. i will try that too!
can i ask one more question. how did you manage your ground routings? did you do it the way the pictures show or did you do something special?
because my ticking noises are causes bei the ground wires off the circuit. thanx so far
friend321
Postby gilmour_pugliese » 23 Jul 2012, 16:46
rs wrote:Hi there, i've built it and it works fine. At first i've had some ticking noises too but then i realise the original has the rate pot wired with shielded cable, i swaped mine and put in some shielded wire too, and that stopped the ticking .
Hope it helps.
I've used the shielded cable with no results... :slap:
My Supatrem has a fucking ticking noise... How could I solve?
gilmour_pugliese
Have thanks: 34 times
Postby blackbunny » 24 Jul 2012, 00:51
gilmour_pugliese wrote:I've used the shielded cable with no results... :slap:
You could try adding a power supply decoupling capacitor to the 9v rail, something like this diagram.
blackbunny
Has thanked: 285 times
Have thanks: 113 times
Postby friend321 » 24 Jul 2012, 15:15
this is not the problem. did anybody get this to work? without ticking?
friend321
Postby gilmour_pugliese » 24 Jul 2012, 18:06
I've used a 1000uF electro, with no results :scratch:
gilmour_pugliese
Postby rs » 24 Jul 2012, 23:10
Hi there gilmour_pugliese,
the diferences from my build is that i've used shilded cable on the conection of the rate pot to the pcb, and i think i've used also on the input and output jacks, i cant remember. The other stuf is pretty much the same, i think R1 on my build is 1.5k instead of 7.5k, R14=8.2k instead of 8.8k, C1 and C4 are non polar.
One thing you should do is not to cross the shielded cable that connects the rate pot to the pcb, with other wires, especeally dc wires.
It worked for me.
rs
Has thanked: 102 times
Have thanks: 7 times
Postby friend321 » 25 Jul 2012, 08:10
i got it to work now. i used shielded cables on the rate pot and switched to a mono pot. left the slow/fast switch. i thought i've done this some days ago without success but this time it's fine. maybe you need luck with this one :)
friend321
Postby gilmour_pugliese » 25 Jul 2012, 17:21
rs wrote:Hi there gilmour_pugliese,
Just some shielded cable on the jacks, and BAM!
The pedal is super-silent :horsey:
Thanks to all for the tips!!!
For this message the author gilmour_pugliese has received thanks:
telecaster (25 Jul 2012, 18:36)
gilmour_pugliese
Postby rs » 25 Jul 2012, 19:44
I'm glad you got it work as you wanted. :D
rs
Postby snail » 21 Aug 2012, 11:22
Hi There
I've heard in a few songs (don't remember, could be radiohead?) a very nice tremolo effect on guitar that seems to ramp down its speed. Chord attack was really fast then in one second or so it would start ramping down utill it was really slow.
Anyone knows if there is a way of implementing this ramping effect in an optical circuit such as this one or the demeter/baja trembulator??
Any other tremolo does that already??
snail
snail
Have thanks: 2 times
Postby Padre Bonic » 30 Sep 2017, 16:51
Hey guys I tried to build one of these with the millennium C switching and I just can’t get it to work. Does anyone have a pcb layout and off board wiring layout so I can make a new board and try again using regular true bypass switching using 3PDTs?
Padre Bonic
Postby gearstack » 09 Feb 2019, 04:26
Bump on this thread
got mine working
Question:
Can I use a DPDT toggle switch on Hard/Soft switch instead of a 3pdt?
Can I just solder the first 2 lugs?
gearstack
Postby Duckman » 09 Aug 2019, 05:26
So, this unit arrive today and I have some spare time to go deeper.
Any way, if somebody spots something funky, lemme kno' :hug:
For this message the author Duckman has received thanks: 3
blackbunny (09 Aug 2019, 05:46), Manfred (09 Aug 2019, 07:36), modman (09 Aug 2019, 10:34)
Duckman
Has thanked: 369 times
Have thanks: 144 times
Previous
Users browsing this forum: Falons1900, gianniotis21, tube65 and 8 guests
