Austone - Vibrostomp [traced]
- KindaFuzzy
- Degoop Doctor
Does it sound like my clip? It is a fairly subtle effect, but should be doing enough to get some good wiggle. I've used 2n4392 for the FETs too and they work fine, shouldn't matter which FETs, you could always plug just the LED in to make sure they're flashing. I used 100uF on the flashers, and it's more than enough. I found if the LEDs were too bright, and the resistance of the LDR went too low, it sounded swampy and dark, and the oposite happened when they weren't bright enough, it sounded like not much was happening. Fairly low brightness clear red ones were the best in mine. 50KA pots work great, just wire them backwards like in my layout. As for the other transistors, I've used both 2sc1815 and mps5172 with gains around 200, and didn't notice a difference. The volume thing is wierd, there should be a bit more than unity when turned up, the stock ones were almost maxed, but had some more volume. I put my volume on the outside as a pot because you could goose the effect volume if you wanted and get a little grit from the amp if it was turned up.
I think mine sounds pretty close to your clips. I tried subbing a 2k for the 50k and I got good travel over the whole pot. It was enough to satisfy me.
- KindaFuzzy
- Degoop Doctor
Cool, whatever works is good. I guess everyone's going to have a slightly different sounding pedal depending on their LED/LDR combo, and might have to play with the flasher circuit.
Okey doke. Here is the the new project document with the PCB artwork and all that stuff.
The Vibrating Stump!
- RnFR
ok, I'll fix it tonight. all this for a bunch of shit that's going to get ditched anyway! but, I guess we should get it right in case anyone wants to fix their vibrostomp one day... hopefully this will be the last time and we can put this sucker to bed and continue moving ahead with our own tweaks. maybe a new thread is in order?KindaFuzzy wrote:No, the base wasn't connected to ground, just the 1k resistor and + end of one of the 2200uf were connected to the base, it looks good otherwise.
- RnFR
ok, finally- presenting the Austone Vibrostomp.
Vibrating Stump!
Vibrating Stump!
- Austone - Vibrostomp
- VIBROSTOMPSCH.png (125.62 KiB) Viewed 3890 times
- KindaFuzzy
- Degoop Doctor
Perfect, that looks great. Now all we need is RG to write a 'technology of the vibrostomp' article and we're set.
- jwpartain1
Hey KindaFuzzy, what is Q4 in your vibrato layout you made?
- KindaFuzzy
- Degoop Doctor
Crap it's not labeled, sorry, 2n5485 or any fet with a DSG pinout.
- jwpartain1
So I'm debugging my build, and I've got the speed knob working as well as the volume knob. The funny thing is that I only get the vibe effect when the depth is maxed (or all the way back in the case of this pedal). When I move anywhere down from max, all I get is clean signal + hum. And the hum is always present. I tried flipping the 2.2 uF cap (where I'm using 4.7 uF, because that's what I had), where now negative side is running to Q3. At first I had a lot of hum, now I've got a little. Any ideas where I could start? I'm going through the whole board tomorrow I guess..
By the way, those FET buffers rock. I notice a huge difference in treble / upper-mids response.
- KindaFuzzy
- Degoop Doctor
Much better eh. The only problems I've had are solder bridges since some of the pads are pretty close together. Or maybe the pinout on the trannies, all the NPNs are EBC and the FETs are all DSG. It looks like your LED is flashing, otherwise you wouldn't get vibrato, maybe your LDR isn't in the right range, I usually measure dark, then stick a 9V battery with a 470R resistor in series and measure the light resistance. Should be 500R-2K on the light side, and over 10M dark.jwpartain1 wrote:
- culturejam
Call Dr. Nomisroseblood11 wrote:Somebody has all the missing files on his hard disk...
- Nocentelli
- Has thanked: 1152 times
- Been thanked: 954 times
