Page 3 of 6
Re: Catalinbread Pareidolia Harmonic Mesmerizer
PostPosted: 06 Jan 2012, 12:52
by roseblood11
LaceSensor wrote:any news on a layout / trace?
If someone (you?) draws a clear schematic, I'll draw a veroboard layout.
But maybe a pcb layout would fit in a 1590B enclosure...
PostPosted: 06 Jan 2012, 13:06
by LaceSensor
Ive more chance of helping with the vero :shock:
PostPosted: 06 Jan 2012, 14:27
by coldcraft
i can provide a PCB layout if someone makes me a clear schematic
PostPosted: 06 Jan 2012, 22:06
by gigelmargel
Hello and thank you KindaFuzzy for your work!
On the schematic that you provide, both outputs of the TL072 (pins 1 and 7) go to "LED", but I can't see any LED in the schematic.
May I suppose that is the bypass LED, which is a pulsating one?
Best regards!
PostPosted: 07 Jan 2012, 00:54
by KindaFuzzy
gigelmargel wrote:Hello and thank you KindaFuzzy for your work!
Best regards!
Oh, yeah they go to either one of the outside positive lugs of a two colour LED, and the center common negative end of that LED goes to the stomp switch, which grounds or ungrounds it to turn it on or off with the effect. You could probably do something similar with two regular LEDs with their negative ends tied together. The stock LED is green/orange but I had a green/red one that was pretty cool too.
PostPosted: 07 Jan 2012, 10:04
by gigelmargel
Best regards!
Thank you very much KindaFuzzy!
Better to ask, because I understood wrong from the schematic.
Best regards!
PostPosted: 08 Jan 2012, 13:31
by hbo
Thanks for the trace, KindaFuzzy.
I'm planning a vero layout for this one so I went ahead and drew up a schematic. Do let me know if I missed something.
PostPosted: 08 Jan 2012, 17:52
by roseblood11
Ah, the uncrowned king of the vero layout joins in! :P
Do you think that it will fit into a 1590b (=21 holes wide), maybe without a battery? Would be great...
Which program do you use to draw schematics?
PostPosted: 09 Jan 2012, 00:31
by roseblood11
Which FET's are used in the circuit? KindaFuzzy wrote "2n5484" at the beginning of the thread, but "2n5485" a bit later... :?:
PostPosted: 09 Jan 2012, 01:23
by KindaFuzzy
5484's are in the original, I used 5485's on the breadboard so I must have put that on the schematic. I think they're almost the same anyways.
PostPosted: 11 Jan 2012, 13:31
by hbo
roseblood11 wrote:Ah, the uncrowned king of the vero layout joins in! :P
I did the schematic in Eagle
As promised here's a vero layout. This one was surprisingly tough, but mostly because I tried to size it for a 1590B (which I think I managed). Hopefully there aren't any mistakes.
PostPosted: 11 Jan 2012, 20:53
by roseblood11
In the first post KindaFuzzy wrote that it's four 2n5484's and two 2n5457's...
Re: Catalinbread Pareidolia Harmonic Mesmerizer  [traced]
PostPosted: 12 Jan 2012, 00:12
by hbo
roseblood11 wrote:In the first post KindaFuzzy wrote that it's four 2n5484's and two 2n5457's...
Ah, didn't catch that.
I've updated the vero layout above, and here's an updated schematic as well.
PostPosted: 01 Feb 2012, 14:16
by Mich P
Is there someone 's done it ?
Mich P.
PostPosted: 01 Feb 2012, 14:23
by Nocentelli
Mich P wrote:Is there someone 's done it ?
Mich P.
Still waiting for the bloody XR2206 chip. I ordered from musikding (only because they had all the parts in one place, so thought i'd save a bit on shipping) but they sent the rest of the order without the chip, which was "to follow"... still waiting. I've got the rest of the board built (lovely layout, thanks hbo!) JUST NEED THE CHIP.... Almost tempted to splash out on an eBay purchase just to get it done.
PostPosted: 01 Feb 2012, 22:24
by Pruttelherrie
hbo wrote:I've updated the vero layout above, and here's an updated schematic as well.
Harold, are you willing to share the eagle schematic so I can have a try at designing a PCB? (Not having to draw the schematic myself saves me some time and averts possible errors!)
Iwan
PostPosted: 01 Feb 2012, 23:30
by roseblood11
Mich P.
I ordered a 2206 and the FET's the day KindaFuzzy started the thread,
but I have to admit that I'm just too lazy to start soldering... :P
PostPosted: 02 Feb 2012, 00:15
by hbo
Built it tonight. Works, and sounds nice too! I had to reorient the depth and rate pots. Rev. 3 is now verified.
by Nocentelli
roseblood11 wrote:I ordered a 2206
musikding?
PostPosted: 02 Feb 2012, 00:18
by roseblood11
no, a german e-bay seller, but too expensive
