Bogner - Ecstasy Red
Re: Bogner Ecstasy Red
Postby Angle Loss » 10 Dec 2012, 03:17
Just googled the Guv'nor schematic...good call! Question, I am unfamiliar with this type of layout and need some help. What would I change to 1) the treble control, it gets very fizzy (very high treble freq) to lower it and, 2) how to I change the mid freq as well (I think I might want to lower that freq)--or any other tips on how to make this tone section better? I find it overall kind of flat sounding, and when getting the treble control is low, it is too dark, yet when raising it, it doesn't really give me treble, only that high fizz. I love the Uber, but this one is bumming me out right now.
Angle Loss
Have thanks: 5 times
Postby Angle Loss » 13 Dec 2012, 02:44
update...
Well...I very basically understand high/low pass filters, but all this parallel stuff leaves me a bit confused (I'm only a hobbiest). I've tried to figure it out the best I can (still don't understand this tone stack real well--mostly the treble area). I decided to desolder the 68n to ground that the treble and bass knobs connect to, and tried a few different values. I decided so far that it sounds best with that cap removed entirely. It opened up the upper mids a bit. I feel that I'm not getting so much tone mush now. I'd like to know about the 2200 cap next to the 2k resistor if someone could explain it to me.
Angle Loss
Postby J0K3RX » 13 Dec 2012, 08:00
What are the pot values? I don't think you are gonna be able to revoice it more like a Soldano SLO like you said in your previous post... most of the tone shaping comes from the first and second jfet stages. All you can do is mess around with the tone stack with the info you have gathered so far...
J0K3RX
Has thanked: 334 times
Have thanks: 522 times
Postby skywise » 13 Dec 2012, 16:10
Angle Loss wrote:Mods...can this be moved to the boutique stompbox area so that it can be discussed more? Thanks!
Yeah, can this topic be moved?
Does anybody read this forum anymore? :scratch:
skywise
Has thanked: 47 times
Have thanks: 20 times
Postby J0K3RX » 15 Dec 2012, 04:16
Guess that's a big no? :roll:
J0K3RX
Postby MoonWatcher » 17 Dec 2012, 03:44
J0K3RX wrote:What are the pot values? I don't think you are gonna be able to revoice it more like a Soldano SLO like you said in your previous post... most of the tone shaping comes from the first and second jfet stages. All you can do is mess around with the tone stack with the info you have gathered so far...
Yeah, the Guv'nor tone circuit is just a passive thing, so it's really just a matter of reducing certain frequencies.
I seem to recall the Guv'nor had 10K pots for all three?
The standard tricks for adjusting high pass or low pass corner frequencies apply. The "extra stuff" versus something like a Marshall amp tone stack is just there to make it a little better as used in pedal format. I believe that the bass filter basically lets you adjust between "more or less," if that makes sense. So even if counter-clockwise, I think it's still rolling off some treble.
I think that Barber modified some of the Marshall pedal tone circuits with the Dirty Bomb. So when you reduce the treble, you are also basically increasing the signal that goes to a low pass filter at the same time. It might just take an extra component or two.
If the treble is too bright and making a high pass filter cap larger doesn't work so well, making the pot bigger to cut more at that frequency might help. Another possibility would be to add some series resistance after the cap if you don't want to replace the pot.
You could also run temp wires to a breadboard to sub caps in and out, and give you an idea of what different values would do to the tone circuit.
MoonWatcher
Has thanked: 43 times
Have thanks: 66 times
Postby EdGrip » 18 Dec 2012, 03:06
MWAHAHA! I fear this excellent forum has met its match!
^_^ I'm watching with interest.
EdGrip
Have thanks: 6 times
Postby Angle Loss » 21 Dec 2012, 02:37
Thanks for moving this thread mods!
After doing some cap swapping, I ended up replacing C116 (the 68n to ground) with a 12n, and modified the low pass filter cap C136 (2.2n) after the treble pot/before the volume pot, to a 3.3n. It opened up the sound quite a bit and then I reduced the fizz with the low pass. The pedal went from being almost sold to a keeper now. The treble control is still weak and gets fizzy above noon, but the EQ range in general is much better and less congested. Thanks for the help, guys.
Angle Loss
Postby bancika » 21 Dec 2012, 11:05
I got very interested in this, but I see quite a few of them being sold on TGP just days after purchase...that means something :)
bancika
Has thanked: 16 times
Have thanks: 89 times
Postby bucksears » 21 Dec 2012, 17:47
Interesting - I noticed some of the empty part locations on the board (unless they are on the bottom); wondering if they use the same board for the Blue as well?
And I'm kinda surprised that someone opened up the Red before taking a crack at the Blue. The latter seems to get more overall favorable reviews.
I had a Blue for a couple of days and returned it; the dealbreakers were the overall lack of gain in standard (non-boosted) mode and the volume jump with the boost mode engaged and the BOOST VOLUME AT MINIMUM. Should be a way to analyze/fix those two shortcomings, but saw the SMD parts and gave up.
bucksears
Have thanks: 45 times
Postby chuckjaywalk » 21 Dec 2012, 17:54
I just got a Blue last night, via a contest I won. I didn't have time to mess with it too deeply, but it is really fantastic. Less a distortion pedal and more like a second channel for my shitty little amp. With the Variac on in Plexi mode, it is sheer beauty.
chuckjaywalk
Postby J0K3RX » 21 Dec 2012, 18:25
I am interested in the Uberschall over any of them.. I think Goosoniqueworx SeventHeaven is pretty much the best Ecstasy pedal at the moment. Not very many of the Uber pedals except for the Bogner...
J0K3RX
Postby ansil » 01 Jan 2013, 10:42
i played the red one and can say yeah i found the eq to be not that inspiring. i haven't taken one apart, however i can say that if it is a marshall eq like the guvnor then try putting in 25k pots. the old purplexed did that and kept the same eq as the guvnor and it was much more amp sounding to use a cliche
ansil
Have thanks: 13 times
Postby guiltyspark » 09 Jan 2013, 03:30
Just want to say thx to the forum members for posting pics of these! I don't think we'll be cloning these anytime soon, judging by the gut shots. I kinda want the Über pedal but I own the amp so it seems stupid to buy the pedal. :slap: There seems to be quite a few of these on eBay at $220ish, I might just wait for a deal on one.
guiltyspark
Have thanks: 38 times
Postby Saruman_ » 26 May 2015, 11:38
any news?
Saruman_
Have thanks: 32 times
Postby Saruman » 15 Jun 2016, 13:07
any news? 2016!
Saruman
Have thanks: 124 times
Postby Saruman » 28 Jun 2016, 11:11
I think that the owners of this pedal is very lazy people. :hmmm: It's been 3 years, and the schematic is not! I buy and wait for La Grange. I need 5 days to draw schematic! :popcorn:
For this message the author Saruman has received thanks: 2
dv8r601 (26 Nov 2017, 17:56), orcl2 (27 Jan 2017, 00:19)
Saruman
Re: Bogner - Ecstasy Red
Postby dv8r601 » 26 Nov 2017, 17:59
That gooped board looks awful familiar after seeing the degooped la grange "top secret" board I'm really interestes to see if that part is different or the same module with the external parts on the main audio board doing all the heavy lifting. Thanks all for posting pics and taking these stupidly expensive pedals apart for us to gawk at.
dv8r601
Has thanked: 409 times
Have thanks: 23 times
Postby Saruman » 27 Nov 2017, 18:56
Saruman
Postby Stephanovitch » 10 May 2018, 20:24
Bogner ecstasy red.pdf
This is secret part of red ecstasy:
https://www.dropbox.com/s/0ehinjrbukbqn ... d.pdf?dl=0
:D
For this message the author Stephanovitch has received thanks: 2
Intripped (10 May 2018, 21:53), irvan_mustaine (23 Jun 2019, 19:05)
Stephanovitch
Have thanks: 16 times
Users browsing this forum: art7710, tube65 and 9 guests
