TC Electronic - Spark Booster  [traced]
Re: TC Electronic - Spark Booster
Postby johnk » 22 Jul 2014, 05:36
I finally got my spark booster clone mounted in its enclosure. being that the veroboard was so large, I was kinda surprised that I could actually fit it into a 1590B (YAY).
For this message the author johnk has received thanks:
rcustoms (22 Jul 2014, 05:48)
johnk
Has thanked: 33 times
Have thanks: 275 times
Postby micromegas » 22 Jul 2014, 10:21
johnk wrote:I finally got my spark booster clone mounted in its enclosure. being that the veroboard was so large, I was kinda surprised that I could actually fit it into a 1590B (YAY).
[ Image ]
[ Image ]
nice!! What relay board is that by the way? It seems small enough to fit a 1590A....
micromegas
Postby johnk » 22 Jul 2014, 15:04
micromegas wrote: nice!! What relay board is that by the way? It seems small enough to fit a 1590A....
it's a monomonster RBM that I purchased from smallbear.
http://www.smallbearelec.com/servlet/Detail?no=1379
Sari (23 Jul 2014, 07:25)
johnk
Postby Yazoo55 » 28 Jun 2015, 17:12
Miklax, would you be prepared to make your pcb layout available please?
Yazoo55
Have thanks: 10 times
Postby floris » 14 Jul 2018, 16:02
I have just repaired a Spark Booster, that did not power up, by replacing R46 1 Ohm, that is in series with the protection diode D9 (D7 in the schematics), with a jumper wire. R46 in this pedal was not 1 Ohm (anymore) but 730 kOhm! This resulted in not having +9V power on the PCB.
After R46 was jumpered, all was working well again!
Some PCB pics:
floris
Has thanked: 185 times
Have thanks: 59 times
Postby Flux Density » 07 Jul 2019, 09:22
Hi all,
IIRC that's my first post in this forum, so for starters a simple question: would it make sense to power the Spark with 12 or 18 volts for more headroom? The listed op amps here can all take it according to their data sheets.
Cheers!
Flux Density
Postby floris » 07 Jul 2019, 11:24
You have to check if the electrolytic capacitors can handle the higher voltages.
floris
Previous
Users browsing this forum: No registered users and 9 guests
