Crowther Audio - Prunes & Custard
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
Hi Richard - sorry for the confusion - i was not sure if they were verified values on your earlier pic with values added
Did you measure the resistor immediately to the left (looks like 390k)
- theblackman
no, i didn't measure that one, (you are talking about the vertical one right?)
- bajaman
yes
- bajaman
I have adjusted the resistor values on my PCB and layout for the Ham and Mustard - The values shown on Krome Magnon's last schematic appear to be correct - many thanks to Richard ( the blackman ), for measuring and confirming values etc.
Don't forget to hit F5 to refresh your browser if viewing the new photobucket file.
- bajaman
I have made some further corrections to the PCB layout , so that the switches and pots are more evenly symmetrically spaced. Please download the amended version from the earlier photobucket link - sorry for the inconvenience
- krome_magnon
So the 2 diodes and resistor I have marked up as "possibly not fitted" were never there in the first place, though the holes exist for them? If so I'll remove them fron the next version of the schem.theblackman wrote:hi guys, when I dismantled the P&C there were a number of components under the goop which had been damaged by my scraping, fortunately only the diodes were broken and easily replaced.
Thanks for doing that, and the values on my last schem are pretty much as per your earlier image and what we have bashed out in this thread?theblackman wrote:The resistors that you are asking about had some of the markings partially scraped off so I desoldered and measured with a DMM and made sure what was left of the markings agreed with the DMM reading.
I'll do a final version crediting the board for figuring it all out but if anyone want's to do a better schem please jump in, I only had a whack at it because this thread seemed to have stalled.
The noise from the tape deck was only drowned out by the buzz from the wine.
- bajaman
Thanks Krome for your schem
- Bernardduur
Bajaman, your layout has a slight error
On the bottom, the mix pot connections are wrong. The line of the drive potmeter should go to the most right leg of the mix potmeter
Now it won't mix a lot
- bajaman
OOOOOPs
sorry - thanks for recognizing the error Bernarduur - I have amended it - don't forget to press F5 to refresh your browser for the new image.
- krome_magnon
Before I edit the schem to be the final version, was the CP10H correct or was it a CP104?
Was it the 10 Volt zener or the rectifier diode?
- bajaman
Judging by the physical colour, and on past Paul Crowther pedals, it is a zener - for over voltage protection or more probably for regulation to avoid uneccessary hum,when used with an unregulated 9v dc power supply (usually put out at least 12v dc).
- krome_magnon
- theblackman
Correct.krome_magnon wrote:So the 2 diodes and resistor I have marked up as "possibly not fitted" were never there in the first place, though the holes exist for them?
Yep, that's right.krome_magnon wrote:Thanks for doing that, and the values on my last schem are pretty much as per your earlier image and what we have bashed out in this thread?
- Bernardduur
Hey Bajaman!
Two more mistakes!
- The switch names are reversed
- You miss a trace between pin 1 and the line connecting the 2k / 10 uF
Two more mistakes!
- bajaman
Amended earlier photobucket link to PCB and Layout - many thanks to Bernardduur for spotting my mistakes, and sorry for any inconvenience.
How does it sound Bernadduur - apparently it is more suited to bass guitar.
ps: don't forget to press F5 to refresh your browser image.
