Boutique Jordan Bosstone: KFA Fuzzly Bear  [traced]
Re: Boutique Jordan Bosstone: KFA Fuzzly Bear
Postby EmmG » 16 Aug 2017, 15:01
Less compression and more volume. Someone used my layout but with switchable LED's. EHX has a Bosstone clone without any clipping diodes at all.
EmmG
Has thanked: 16 times
Have thanks: 38 times
Postby bc108 » 16 Aug 2017, 15:51
EmmG wrote:Less compression and more volume. Someone used my layout but with switchable LED's. EHX has a Bosstone clone without any clipping diodes at all.
You're right... I don't reminded the parallel/series diodes properties.
I used on-off-on switch with 1n4148 in one side, red leds on another, and nothing in the middle.
That way I have the 3 options.
bc108
Has thanked: 20 times
Have thanks: 2 times
Postby Sasan » 11 Dec 2017, 11:26
Hi all,
first, thanks for the layout of one of the nicest Fuzz pedals out there. I'm a huge KMA fan and own the Fuzzly Bear already!
Nevertheless, I wanted to copy the pedal for a friend of mine....unfortunately, it's not working.
I double-checked everything, cut the lines to make sure there's no connection, etc...I can't seem to find the problem! :scratch:
Bypass works, as do the LEDs when I switch the pedal on...I probably overlook something
Any help is appreciated!Thanks in advance!
Here's two pics of the stripboard:
Image Image
Sasan
Have thanks: 3 times
Postby EmmG » 11 Dec 2017, 17:29
The 4001 is backwards. Also, lug#1 of the pregain pot should go either to row "H" if you choose not to place the pink resistor, or row " K" if you do - not both.
For this message the author EmmG has received thanks:
Sasan (11 Dec 2017, 19:59)
EmmG
Postby Sasan » 11 Dec 2017, 20:01
EmmG wrote:The 4001 is backwards. Also, lug#1 of the pregain pot should go either to row "H" if you choose not to place the pink resistor, or row " K" if you do - not both.
Wow, thanks for your fast reply! I can't believe I've put 4001 in backwards... :scratch:
And thanks for the clarification with lug#1...! Didn't know that as this was my first pedal not based on a kit! :) Thanks a lot!
Sasan
Postby wompikus » 18 Jun 2019, 20:00
So something weird is happening.. I built it and could never get it to work, until I put it in chain with my other pedals and supply, and suddenly it worked fine! Sounds great. I tried it again by itself and all it does is buzz and hum and not in the good fuzz way, more like licking a cable going into an amp. Any ideas why this would happen?
wompikus
Postby Intripped » 18 Jun 2019, 20:16
bad ground connection somewhere, IMO.
Intripped
Has thanked: 659 times
Have thanks: 235 times
Users browsing this forum: Chugs, Google Adsense [Bot], jovesdies, NegationOfNegation and 7 guests
