Wampler Pantheon  [traced]
Wampler Pantheon
Postby FeVeR2112 » 03 Oct 2018, 06:18
While some will say this is a clone type of the BluesBreaker pedal.... I would like to think that Brian went steps further .... I have one of these in the shop for a bit and took a dive under the hood.
First thing I noticed is that the board was labeled "Paragon 02-2017b" - a working title?
Then the usual kind of thing.... lots of chiclet caps, resistors, etc... A modern board design with an MCU, relay etc.
Now with added Gyrator EQ (per Brian on FB) and diode switching.... I am still curious of what else was tweaked in here. Or even what these more 'modern' board designs contain.
If folks are interested in trying to dissect this microscopic PCB, I can setup for detail (macro) photos and discussion. Please chime in.
:D
For this message the author FeVeR2112 has received thanks: 2
modman (17 Mar 2019, 13:13), thesmokingman (05 Oct 2018, 00:06)
FeVeR2112
Has thanked: 22 times
Have thanks: 34 times
Re: Wampler Pantheon
Postby lukatosh » 03 Oct 2018, 12:44
Even though many values will be a complete mystery...i'm interested on those photos! Thanks so much FeVeR2112!
lukatosh
Has thanked: 33 times
Have thanks: 180 times
Postby thesmokingman » 04 Oct 2018, 02:26
Image that should shorten your work
thesmokingman
Have thanks: 8 times
Postby roseblood11 » 04 Oct 2018, 07:06
Why are some parts blurred?
roseblood11
Has thanked: 360 times
Have thanks: 326 times
Postby Ben N » 04 Oct 2018, 08:08
roseblood11 wrote:Why are some parts blurred?
Japanese pedal porn? :mrgreen:
For this message the author Ben N has received thanks: 3
dv8r601 (08 Oct 2018, 22:09), jimini (05 Oct 2018, 16:59), Nocentelli (05 Oct 2018, 05:54)
Ben N
Has thanked: 28 times
Have thanks: 15 times
Postby indyguitarist » 04 Oct 2018, 16:17
I can't just *give* you all the schem, there's got to be a least some mystery, no? :mrgreen: :P
For this message the author indyguitarist has received thanks: 3
dv8r601 (08 Oct 2018, 22:09), IvIark (04 Oct 2018, 22:25), karul (04 Oct 2018, 21:23)
indyguitarist
Have thanks: 162 times
Postby indyguitarist » 04 Oct 2018, 16:19
FeVeR2112 wrote:While some will say this is a clone type of the BluesBreaker pedal.... I would like to think that Brian went steps further .... I have one of these in the shop for a bit and took a dive under the hood.
:D
As mentioned in this article (http://www.wamplerpedals.com/news/blog/ ... ted-pedals ) it was originally going to be called the paragon
indyguitarist
Postby thesmokingman » 04 Oct 2018, 17:23
well the gain switching is in the feedback loop of the first op amp adding series resistance to the gain pot and that should be easy enough to suss out, blurred or not ... R6, R7, R8 in the pictures
thesmokingman
Postby Güero 2.0 » 04 Oct 2018, 19:36
For this message the author Güero 2.0 has received thanks: 2
IvIark (04 Oct 2018, 22:26), karul (04 Oct 2018, 21:23)
Güero 2.0
Have thanks: 25 times
Postby thesmokingman » 04 Oct 2018, 23:35
r6 - 47K
r7 - 1M
r8 -1M
looks like low gain is 47K, high gain is 1M in series, med is 500K in series
r21 4K7
c18 1u
could use c8, c15, c17 and of course much better shots of the bass pot area
thesmokingman
Postby FeVeR2112 » 05 Oct 2018, 04:36
I will be back in the shop tomorrow so expect some macro shots soon. :arrow:
FeVeR2112
Postby FeVeR2112 » 05 Oct 2018, 04:48
One I didn't upload yet.
FeVeR2112
Postby FeVeR2112 » 05 Oct 2018, 08:50
I had a little look at the Gain switch area and came back with this:
Maybe be a better way to draw it in schematic. :)
On the board, it is laid out roughly like this:
FeVeR2112
Postby FeVeR2112 » 05 Oct 2018, 08:56
.... and the switch is ON-OFF-ON type.
FeVeR2112
Postby roseblood11 » 05 Oct 2018, 09:21
are you sure about the switch wiring? This way, it wouldn't be logical: three gain settings, but the highest one would be in the middle position
roseblood11
Postby thesmokingman » 05 Oct 2018, 13:01
yes, he is correct according to the product manual
thesmokingman
Postby FeVeR2112 » 06 Oct 2018, 06:19
I am now cross-eyed with my tracing effort, but I think I may have the layout of the Bass Control section worked out. I know my schematic drawing isn't the best but ... LOL
I can't get the C11/C13 cap values as these are unmarked SMD chiclets ... perhaps Brian can fill in that small gap so I don't have to get the reflow gun out and disassemble/measure it. :P
If this is correct, we can discuss how this all works.
In addition to the main circuit, there is a relay chip which replaces the usual true-bypass 3PDT foot-switch. With all the room afforded by the smd parts, this works well.
Let the discussion begin! :horsey:
FeVeR2112
Postby FeVeR2112 » 06 Oct 2018, 06:40
The Diodes D1-D6 are marked A2 14 - which I believe are 1N4148 types.
FeVeR2112
Postby FeVeR2112 » 06 Oct 2018, 06:47
Other values missing in the schematic:
C8 4u7 50V
C15 4u7 50V
C17 1uF 50V
C18 1uF
R21 4k7
modman (17 Mar 2019, 13:14)
FeVeR2112
Postby FeVeR2112 » 06 Oct 2018, 07:29
redrawn to better match the blurry schematic....
FeVeR2112
Next
Users browsing this forum: cpage86, Improviser and 3 guests
