Keeley - Katana
- ryanuk
LJDA - good job with the layout - which program did you use???
Jimib - as requested, here is the top and bottom views of my layout - just print them at 100% and they are the right size. Also attached is a blow up of the layout.
Im pretty sure this is correct but please please please - everyone who has a katana please post more pics just so we can be sure.
Peace, out.
RyUK
Peace, out.
RyUK
- Keeley Katana Boost PCB TOP.pdf
- (22.93 KiB) Downloaded 969 times
- Keeley Katana Boost PCB LAYOUT.pdf
- (28.45 KiB) Downloaded 1041 times
- Keeley Katana Boost PCB BOTTOM.pdf
- (22.86 KiB) Downloaded 782 times
- bacaruda
Katana arrived. The transistors in this one are 2N5484. I can't make out the diode markings, but I don't think they match those in the schem. I'll look it over tonight with a magnifying glass and post close-up photos tomorrow.
Not built yet but looks right, any mistakes tell me.
Component numbering same as pdf schematic ...
- bacaruda
Okay, spent some time tracing the Katana last night. This one has a few different part values.
RF cap is 220pF
Transistors are Fairchild 2N5484
Pot is 250k Audio taper
Small red diodes are unknown - I can make out V41 . . . any guesses before I desolder?
Please check schem for errors, thanks.
RF cap is 220pF
- KATANA.pdf
- schematic
- (133.73 KiB) Downloaded 1307 times
- analogguru
I doubt that it is a 1N4148 - measure the voltage across
it, if it is less than 0,5V than it is a schottky-diode.
BTW, doesn´t this unit produce a pop-noise when S2 is activated ?
mmm, ¿could it be a zener diode?, they typically have a V, but then we would be missing the first number...
I apologize for not getting to this. My wife and I just had our second child so I've been a bit distracted. I will try to get to it as soon as possible.
ryanuk wrote:95strat - any update on these pics??95strat wrote:That does look good. I'll try to shoot some pics tomorrow to see if I can clear up any questions you may have.
- ryanuk
95strat - no worries. Didnt mean to push. Congrats on your new baby!! My wife and I are expecting our second early next year.95strat wrote:I apologize for not getting to this. My wife and I just had our second child so I've been a bit distracted. I will try to get to it as soon as possible.
Ry
- ryanuk
bacaruda - great job on the schematic. I've checked it against mine and they appear to be the same in principle ... ... save for the different values you identified for C10 and the diodes.
Any chance you could desolder so we can finally put this thread to rest??
Also the datasheet for the MAX1044 recommends shottky diodes for this application. Not sure if this helps.
It makes sense that they're schottky diodes, to get the most juice out of the voltage doubler.
Has anyone built this yet? I am having a problem with this circuit.
The circuit works fine except for when I engage the bypass cap C4 (of course, at the same time C4 is engaged, so is C3).
When I engage the bypass cap, the low end strings (most notably, E and A) get flabby. It sounds OK with relatively light picking, but if I start to chug away (i.e. Metallica’s Master of Puppets), the low-end strings flab out.
Any hints or tips on how to fix this?
Also, what should my voltages at the drain of Q1 and Q2 be? I get around 11.5V which seems high.
Many thanks in advance.
OverDriveManiac
PS: This was my fisrt post so I hope I am not too much of a noob.
OverDriveManiac
Can anyone help?
OverDriveManiac
OverDriveManiac
- rocklander
- Has thanked: 1406 times
- Been thanked: 231 times
- Contact:
sorry bro.. not tried to build as yet.. I know I kicked this thread off, but since I built the bajaman black toast my boost is covered and other stuff has gotten priority over playing with this oneOverDriveManiac wrote:Can anyone help?
OverDriveManiac
