Freakshow Effects Boost Schematic tracing?
Postby jaredcohen » 25 May 2019, 06:14
Hey guys. My cousin gave me his broken Freakshow Boost and asked me to fix it. I can't find a schematic anywhere, and I don't really know how to trace a PCB. It only has a handful of components. Just wondering if anyone would be willing to trace it for me? You'd need photos of both sides of the board, right? As a perk, others will be able to build it, since I think Freakshow stopped building. My cousin said it was the best sounding boost he'd ever played before it bit the dust.
jaredcohen
Re: Freakshow Effects Boost Schematic tracing?
Postby roseblood11 » 25 May 2019, 09:48
Photos of both sides of the pcb. Maybe some shots against a bright light, so that you can see the connections through the board. And you should write the parts list, as it's hard to read the values and colour codes from photos.
If you're in bright daylight, a smartphone camera is a very good tool for close-up photos
roseblood11
Has thanked: 356 times
Have thanks: 325 times
Postby jaredcohen » 29 May 2019, 22:41
Here are some pics. I took a bunch of angles since it's hard to see around the switch.
For this message the author jaredcohen has received thanks:
dv8r601 (29 May 2019, 23:01)
jaredcohen
Postby dv8r601 » 29 May 2019, 23:12
boost side of this(left hand side) looks mighty similar
http://freestompboxes.org/viewtopic.php?f=73&t=28706
dv8r601
Has thanked: 409 times
Have thanks: 23 times
Postby tip142 » 30 May 2019, 06:42
Hi i see a suspicius resistor on the left side near a green capacitor....
tip142
Have thanks: 16 times
Postby karul » 30 May 2019, 15:39
this one. it seems that it's value is 4.7k *yellow - violet - black - brown - brown).
karul
Has thanked: 293 times
Have thanks: 184 times
Postby Nocentelli » 30 May 2019, 22:29
Something like this?
jaredcohen (31 May 2019, 04:24)
Nocentelli
Has thanked: 918 times
Have thanks: 864 times
Postby jaredcohen » 31 May 2019, 04:15
Nocentelli wrote:Something like this?
Thank you for drawing this up! I didn't want to ignore your post but I've got a busy few days coming up. Hopefully I'll have a chance to look at this in depth over the weekend.
[EDIT]: Oh, so it's an LPB-1... :-)
jaredcohen
Postby Manfred » 31 May 2019, 04:43
Rather, like this circuit pattern:
For this message the author Manfred has received thanks:
jaredcohen (31 May 2019, 05:42)
Manfred
Has thanked: 1085 times
Have thanks: 690 times
Postby jaredcohen » 31 May 2019, 05:39
Ah good catch. It looks like the difference from an LPB-1 is the 511k resistor (in this case) going to the collector, versus to V+. It's amazing how many pedals are Jack Orman's circuits with a few value swaps.
jaredcohen
Users browsing this forum: art7710, d312a, kikback007, storzio, vtguedes and 7 guests
