Rainger FX - Minibar
- modman
- a d m i n
- Has thanked: 4394 times
- Been thanked: 2131 times
Corksniffer's delight!
- deltafred
- Opamp Operator
Crazy, but I'm sure it gets people to their booth.
- soulsonic
my guess is the resistance of the liquid between those two screws determines gain, and an LDR determines tone.
fun idea!
fun idea!
- modman
- a d m i n
Never felt more like buying a pedal!soulsonic wrote:my guess is the resistance of the liquid between those two screws determines gain, and an LDR determines tone.
fun idea!
"From the liquid solutions chosen, orange juice is the best electrical conductor and distilled water is the worst. From this we understood that orange juice has more ions present than distilled water (pure H2O). Therefore our assumption regarding acidic solution has high electrical conductivity is correct. Adding to the above results, the density and temperature also affects the electrical conductivity. The more salt added to the solution i.e. more ions added, the lesser the electrical resistance. The assumption regarding temperature as a factor affecting electrical conductivity was correct in some measure as some liquid solutions show higher resistance whereas some show almost the same resistance value with the room temperature values."
https://www.ukessays.com/essays/biology ... -essay.php
- FuzzMonkey
What would you use to get the 'Brown Sound'?
- Manfred
- Has thanked: 1671 times
- Been thanked: 1344 times
I hope there will be a decanting modification soon so you can switch the sound during the performance.
A crazy pedal from a crazy guy only suitable for crazy musicians?
- EddieTavares
chorume!FuzzMonkey wrote:What would you use to get the 'Brown Sound'?
- EddieTavares
Is it possible to be a Expandora based circuit?
