Cornish P-2 guts
Re: Cornish P-2 guts
Postby aionios » 21 May 2019, 18:39
JBJ wrote:
analogguru wrote:Normally I have no intention to waste my time by responding to paranoid false accusations without any substrate. But since this is a theme of general interest I will respond in this special case.
The basic technology of the "mythical Cornish Buffer" is well known since the early 60´s an was already used in the germanium era as you can see here:
[ Image ]
The technology is called "bootstrapping" whereby a portion of the signal is fed back to the bias divider to increase the input impedance. The darlington configuration shown is only necessary with low-gain (hfe ~ 80) transistors as the 2N1309.
So where is the difference to the Roland AP-2 buffer I mentioned ? First, here is a redrawn version:
Analogguru AP-2-style Buffer schematic
So what is obvious is that the bias for the first stage is not taken from V+ instead it is taken from the collector of Q1 via R2. This leads to an additional (AC and DC) feedback resulting in more temperature stability, lower distortion/increased headroom and lower collector output impedance.
Then you can see that the signal is not taken from the emitter instead it is taken from the collector. You can ommit Q2 and R7 if you only want to drive "high impedance" stages.
Because the signal is taken from the collector, the first stage even has a (small) gain of 2 (6 db). The second transistor doesn´t amplify, it is only a buffer to lower the output impedance (< 100 Ohm). That´s important when driving long cables.
Overall it can be expected that the "AP-2-Buffer" has:
a higher input impedance,
a lower output impedance,
less noise,
less distortion,
and even a small gain
compared with the "mythical Cornish Buffer" - with only 2 additional components.
Does anyone have the schematic of the AP-2 buffer redrawn by Analogguru?
Seconding the request... did anyone happen to save it? It's not pulling up on archive.org either.
Aion Electronics - DIY PCB projects for classic and obscure circuits
aionios
Have thanks: 151 times
Postby Cub » 21 May 2019, 19:51
Not by Analogguru, but perhaps this is of any help until the file that he drew surfaces.
Cub
Has thanked: 81 times
Have thanks: 92 times
Postby JBJ » 16 Jun 2019, 01:05
Cub wrote:Not by Analogguru, but perhaps this is of any help until the file that he drew surfaces.
Hi. Thank you for the layout. But I'd like to see the Analogguru's schem... :cry:
Does anyone?
JBJ
Previous
Users browsing this forum: No registered users and 10 guests
