Lovepedal - Les Lius  [traced]
Postby 3PDT » 20 Jul 2009, 00:56
Picked this guy up and figured I'd post the guts. Got a new camera and the macro works really well. I was happy with the results. If anyone wants the original i.e. LARGER pictures, just lemme know, I'll send them to you directly. Also, if you'd like pictures from alternate angles or part values please just hollar.
You may notice an empty connector, it's for the battery. The battery connects to the board just like the switches. Funny thing is, the switching isn't really silent. I can hear a little click when they engage. Enjoy
For this message the author 3PDT has received thanks:
culturejam (01 Apr 2011, 15:07)
3PDT
Re: Lovepedal Les Lius gut shots...warning, big
Postby culturejam » 20 Jul 2009, 01:28
Well done, sir. Well done.
:applause:
culturejam
Has thanked: 468 times
Have thanks: 584 times
Postby kurtlives » 20 Jul 2009, 05:59
Nothing says bow tweek like SMD! :x
kurtlives
Have thanks: 5 times
Postby Greg » 20 Jul 2009, 06:13
kurtlives wrote:Nothing says bow tweek like SMD! :x
In this case, nothing says built elsewhere by other people, than the way it's built and the components.
Greg
Has thanked: 77 times
Have thanks: 195 times
Postby ChrisFFTA » 20 Jul 2009, 07:47
Sorry I am a little slow on the uptake... what do you mean?
ChrisFFTA
Have thanks: 3 times
Postby Jack Deville » 20 Jul 2009, 08:06
12F675...
relay switching....
this is my first post here. so i'll keep it short.
this design is very intriguing....
lovepedal? :secret:
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
Jack Deville
Have thanks: 91 times
Postby Greg » 20 Jul 2009, 08:31
I mean the boards aren't done by Mr LP.. they're outsourced.
Greg
Postby soulsonic » 20 Jul 2009, 10:03
My first guess is a single transistor boost with clipping diodes. The switch changes between different diodes. Everything else is for controlling the relay.
Has thanked: 68 times
Have thanks: 291 times
Postby culturejam » 20 Jul 2009, 13:14
soulsonic wrote:Everything else is for controlling the relay.
Damn. That seems like an awful lot of components just for switching. Why the hell would you make a bypass switch so complex? If your guess is correct, then the switching is about 5x the complexity of the effect part of the circuit.
:scratch:
culturejam
Postby MoreCowbell » 20 Jul 2009, 18:24
soulsonic wrote:My first guess is a single transistor boost with clipping diodes. The switch changes between different diodes. Everything else is for controlling the relay.
SMD Electra-like circuit. That was my guess as well, would be funny if that were indeed the case.
Should be able to compare the switching to Cusacks pedals. IIRC, Cusack designed the switching for Sean.
I could certainly be wrong about everything in my post though ! :lol:
MoreCowbell
Have thanks: 11 times
Postby reveriesof » 20 Jul 2009, 19:55
ive always assumed it's the woodrow/electra mod w/ a diode switch, cos it's sposed to be a "5E3" aye?
reveriesof
Postby RnFR » 20 Jul 2009, 23:28
reveriesof wrote:ive always assumed it's the woodrow/electra mod w/ a diode switch, cos it's sposed to be a "5E3" aye?
no, it's supposed to be a supro. :roll: :lol:
Has thanked: 150 times
Have thanks: 175 times
Postby Jack Deville » 11 Aug 2009, 19:51
3PDT:
how loud is the click when the effect is engaged? is it from the relay only, or is it audible through the amp?
www.jackdeville.com
Jack Deville
Postby roseblood11 » 11 Aug 2009, 20:57
Aren´t all Lovepedals "Electra like circuits"?
Except for that famous one, which is a son-of-a-screamer like circuit... :roll:
For this message the author roseblood11 has received thanks:
pingone (07 Sep 2012, 18:50)
roseblood11
Has thanked: 354 times
Have thanks: 321 times
Postby ampjunkie » 18 Aug 2009, 19:04
The relay circuit by Cusack is pretty small. Does anybody know if he does the layouts as well? I doubt Sean does much these days except count the money flowing in. :mrgreen:
For this message the author ampjunkie has received thanks:
randalp3000 (30 Jun 2016, 18:57)
ampjunkie
Re: Lovepedal Les Luis gut shots...warning, big
Postby cbriere » 09 Sep 2009, 02:35
3PDT, do you got a chance to trace it? i think i'm not alone curious to see this circuit :roll:
cbriere
Have thanks: 8 times
Postby culturejam » 09 Sep 2009, 02:47
cbriere wrote:3PDT, do you got a chance to trace it? i think i'm not alone curious to see this circuit :roll:
Negative. If he had traced it, it would be in this thread.
culturejam
Postby WhiteKeyHole » 09 Sep 2009, 02:51
It's a Woodrow with switchable diodes. Looks like only one half of the pair is switched. Can't decipher the boost function at a quick glance, but looks like it might switch from a fixed gain setting to a variable control.
WhiteKeyHole
Has thanked: 41 times
Have thanks: 231 times
Postby WhiteKeyHole » 09 Sep 2009, 05:04
OK, this is only speculation based on what I see;
Even though the ad copy suggests that the boost activates a cascaded gain stage, I do not see the second transistor (setup) that would make this true.
What I do see is Q1 acting as, what I assume, is a VVR in series with VR4, both in parallel with the Q20's emitter resistor (330R). When the JFET's resistance is high (assume 1Meg with boost off), the affect on the 330R is very little, but when it is low (assume 1R with boost on), VR4's (variable resistor) value of 1R to 1K in parallel with the 330R increases the gain of Q20 by dropping the resistance.
Maybe?
WhiteKeyHole
Postby WhiteKeyHole » 09 Sep 2009, 05:51
WhiteKeyHole wrote:Looks like only one half of the pair is switched.
Wrong, sorry. A BAT46 pair in the 5E3 position, a BAV99 in the Tweed Twin position. In the Tchula position, a single BAT46 is put in parallel with the BAV99, for asymmetrical clipping.
Now you can build one.
WhiteKeyHole
Next
Users browsing this forum: beniboy87, centraleuropean, jhergonz, orya01 and 7 guests
