Lovepedal - Les Lius  [traced]
Re: Lovepedal Les Luis gut shots...warning, big
Postby WhiteKeyHole » 13 Oct 2009, 02:59
Looks correct as is.
WhiteKeyHole
Has thanked: 41 times
Have thanks: 231 times
Postby WhiteKeyHole » 24 Oct 2009, 23:12
Not all FETs are ideal for switching applications. I don't think there's anything wrong with how I've implemented it. Better to go the less convoluted route, anyways. As mentioned earlier, put a large value resistor (4.7M) in parallel with the switch to avoid popping.
As for being less bright, it's possible that the input and output capacitor values are not correct. I went with the values used in the Woodrow. Brightness is affected by the gain of the transistor used, as well.
WhiteKeyHole
Postby cbriere » 25 Oct 2009, 21:48
here is my build
i used the last schematics version found here, except for the shottky diodes. I have put 2 in series to have same output volume whem switching between modes.
I really like the sound of it.
cbriere
Have thanks: 8 times
Postby cbriere » 25 Oct 2009, 23:26
no FET switching, footswitch straight,
cbriere
Postby blueskiwi » 31 Oct 2009, 00:53
I'm not a builder, just a player... I recently bought a Les Lius. It sounds great, pretty much spot-on tone wise, but I don't understand why there's no gain control for the basic sound, just on the 'stack' channel.
For my taste there's just too much gain/distortion in the basic sound and I can't turn it down (only volume-wise).
Since you folks have dissected the pedal I was wondering if it this was some limitation of the circuit type, or just a design decision to please the power-chording bedroom-guitarists who must make up the bulk of the pedal buying market?
Any suggestions for similar sounding pedals around to try?
blueskiwi
Postby nooneknows » 03 Nov 2009, 23:47
on proguitarshop.com videos there's a A - B test of this pedal againsta real Fender Deluxe, it my be only a woodrow but it sounds pretty close to the original, even better than I thought, interesting
http://www.youtube.com/watch?v=-38-BHcEYfs
nooneknows
Has thanked: 23 times
Have thanks: 6 times
Postby blueskiwi » 04 Nov 2009, 00:03
absolutely, the sound is pretty much spot on. I was looking for a 'substitute' pedal for those gigs where I have to play through a borrowed amp (usually something like a silverface Twin...)
what wasn't obvious to me from the videos is that you can't turn the basic gain down - it's great for the zz top and neil young stuff, but if you want the sound of a Deluxe just starting to break up there's no way to get it...
blueskiwi
Postby RnFR » 04 Nov 2009, 01:02
i found "B" to be the pedal- you could hear the rattiness of the diode clippers breaking up, and the mid range just wasn't there. they matched up the tones better on the reveal vid better though... no surprise- they are out to sell pedals you know.
Has thanked: 150 times
Have thanks: 175 times
Postby sevinisthenumber » 30 Jul 2010, 20:22
Anyone have a layout?
C.S. Lewis
sevinisthenumber
Have thanks: 31 times
Postby okgb » 30 Jul 2010, 21:12
Did you say what kind of camera you used ?
great macro , i can never get mine quite in focus
okgb
Has thanked: 214 times
Have thanks: 43 times
Postby reverend » 09 Sep 2010, 16:19
How the DPDT switch (S2) should be wired? I'm using it instead of spst because I want the led for boost switch also. I'm using the vero layout from the previous page.
reverend
Postby SoulShade » 16 Dec 2010, 00:12
WhiteKeyHole wrote:As for being less bright, it's possible that the input and output capacitor values are not correct. I went with the values used in the Woodrow. Brightness is affected by the gain of the transistor used, as well.
So has anyone verified the layout/schematic have the correct input capacitors, etc.?
SoulShade
Re: Lovepedal - Les Luis
Postby rocklander » 04 Sep 2011, 06:33
grabbed the la vache from madbean and used the schem (thanks madbean!) to make a 1590A layout.
it's squashed dowm so the toggles 'should' fit north of the board.. as yet unverified, but I've checked it a few times.. will be building in the next couple of weeks.. enjoy :block:
lavache-pcb-layout1.1.schem.pdf
rocklander
Has thanked: 1582 times
Have thanks: 290 times
Postby method » 25 Oct 2011, 05:40
Another old layout I downloaded earlier this year. Didn't see it in this thread, so here it is.
method
Have thanks: 61 times
Re: Lovepedal - Les Lius
Postby HHR18 » 23 Jan 2012, 14:44
I just build it using the layout of method but I don't get any sound, only in bypass! When I push on the stripboard near the 9v and ground points it works. Anyone able to help?
HHR18
Has thanked: 18 times
Have thanks: 3 times
Postby Seiche » 23 Jan 2012, 15:55
HHR18 wrote:I just build it using the layout of method but I don't get any sound, only in bypass! When I push on the stripboard near the 9v and ground points it works. Anyone able to help?
resolder the 9v and GND connections.
Seiche
Has thanked: 266 times
Have thanks: 214 times
Postby HHR18 » 23 Jan 2012, 19:27
I did and the voltage reads normal on the 9V lane and 0 on the ground lane. Anything else I might have overlooked? When I push hard on the stripboard, I get a lot more sound coming out of the pedal!
HHR18
Postby Seiche » 23 Jan 2012, 19:32
i don't know what the pushing does. Maybe there is a microscopic trace shorting the tracks between those two. I recommend running a blade between then to clear the tracks. most problems with vero are because of that.
For this message the author Seiche has received thanks:
rocklander (23 Jan 2012, 20:08)
Seiche
Postby HHR18 » 24 Jan 2012, 15:44
Here are some pictures, I cleared the tracks but it's still not working!:
HHR18
Postby Seiche » 24 Jan 2012, 17:11
everything looks to be in the right place.
the other thing could be that the stranded wires unfiddled a bit when pushing them through the hole so there might be a tiny wire going from 9v to gnd, shorting it. try to look on the topside for this. Can be with any of the stranded wires when they are that close. I can't really tell from the photograph but it looks like there might be a tiny wire sticking out from the gnd wire.
like this
Seiche
Users browsing this forum: beniboy87, centraleuropean, jhergonz, orya01 and 7 guests
