Lovepedal - Les Lius  [traced]
Re: Lovepedal - Les Lius
Postby rocklander » 24 Jan 2012, 21:24
looks like you're using a buttload of solder, and some of he joints look like they 'could' be dry (the ones on the stompswitch seem to be not as clean as some I've seen)... when you ran the knife through the tracks, did you also run it between the tracks you cut? I'd be looking there too .. on the solder side pic, the top right trace looks a likely candidate for a solder snot bridge to occur :)
rocklander
Has thanked: 1582 times
Have thanks: 290 times
Postby HHR18 » 12 Feb 2012, 13:52
Ok, I got it working, I stupidly soldered R2 on the 9V track to the ground track. I soldered it onto the 3rd track and it worked immediately. It sounds freaking' amazing! Great pedal!
HHR18
Has thanked: 18 times
Have thanks: 3 times
Postby Nicholas L » 04 Apr 2012, 19:47
Hey guys. I finished building this today using the vero layout and it sounds great, but for some reason the boost doesn't do much that I can notice. Any ideas or suggestions?
Nicholas L
Postby marauder » 04 Apr 2012, 21:38
Nicholas L wrote:Hey guys. I finished building this today using the vero layout and it sounds great, but for some reason the boost doesn't do much that I can notice. Any ideas or suggestions?
Check the resistor on the pot goes between 1 and 3, and not 2 and 3. I had it wrong and the boost didnt do much.
For this message the author marauder has received thanks:
Nicholas L (06 Apr 2012, 12:23)
marauder
Have thanks: 13 times
Postby Nicholas L » 05 Apr 2012, 08:54
Should pin 1 and 2 be connected? Cause that's causing the resistor to connect pin 2 to 3?
I've got the resistor on pin 1 and 3, with a short on 1 and 2. Should I disconnect 1 and 2?
Nicholas L
Postby Nicholas L » 05 Apr 2012, 18:39
I cut the connection between pin 1 and 2 and lo and behold it's all awesome :D :horsey:
Nicholas L
Postby marauder » 05 Apr 2012, 20:45
Nicholas L wrote:I cut the connection between pin 1 and 2 and lo and behold it's all awesome :D :horsey:
Beat me to it.
That's what I found too. I'm not sure if its right or wrong as I've never compared a real one, but it works.
marauder
Re: Lovepedal - Les Luis
Postby crkva » 26 May 2012, 00:23
method wrote:Another old layout I downloaded earlier this year. Didn't see it in this thread, so here it is.
hello everyone!
need some advice as to connecting an led into the circuit..or as it says instead of the spst to use an dpst. how would i have to connect that?
crkva
Postby Seiche » 26 May 2012, 01:39
hello everyone!
for true bypass and LED you need a 3PDT.
if you have a power jack and battery, connect as shown here.
if you have a different configuration, check out this link.
For this message the author Seiche has received thanks:
crkva (26 May 2012, 14:47)
Seiche
Has thanked: 266 times
Have thanks: 214 times
Postby crkva » 26 May 2012, 02:42
Thanks for the links, it will be helpful in the future :D But now i am really confused :slap:
I have 2x 3dpt and an dpdt, but the whole vero layout confusses me.
the switch config isn't the same as the real one, right?
Sorry for all the questions but im new to this :D
crkva
Postby Seiche » 29 May 2012, 19:01
yeah it's a little confusing, not to worry! The real one uses relays and simple spst switches. the vero layout uses actual hardwire switches.
So assuming you want an LED for both the pedal to show if it's on or off and the boost to show when it's on/off, there would have to be a regular 3PDT foot switch that you wire the common way for an LED (use the wiring diagrams I posted). That one is not shown on the vero. It never is. There is only "input" and "output" on the vero going to that switch (because it is assumed you know how to wire a pedal).
The boost switch however is shown. In reality that is a footswitch and should be a DPDT if you want an LED. LED wiring would be like on the 3PDT (here is a nice breakdown how the different parts of a switch are wired. a 3PDT is simply 3 single SPDTs together).
The "mode" switch is a DPDT like here. A simple flip switch. There is no LED for that one.
so 2 footswitches, one of the DPDT, one 3PDT and a flip switch DPDT. If you only have two 3PDT FS you can use them too, just leave one column of pins not connected to anything.
lots of info, hope this helps. Any questions, just ask away. :thumbsup
crkva (13 Mar 2013, 09:53)
Seiche
Postby crkva » 03 Jun 2012, 20:31
thank you very much for all the info! :hug:
this is the info i have been searching :D thanks!
crkva
Re: Lovepedal Les Luis gut shots...warning, big
Postby pallas05 » 02 Sep 2012, 00:16
blueskiwi wrote:I'm not a builder, just a player... I recently bought a Les Lius. It sounds great, pretty much spot-on tone wise, but I don't understand why there's no gain control for the basic sound, just on the 'stack' channel.
For my taste there's just too much gain/distortion in the basic sound and I can't turn it down (only volume-wise).
Since you folks have dissected the pedal I was wondering if it this was some limitation of the circuit type, or just a design decision to please the power-chording bedroom-guitarists who must make up the bulk of the pedal buying market?
Any suggestions for similar sounding pedals around to try?
I'm not so much of a builder as well, so I bought the Les Lius.
After some playing I have the same question as "blueskiwi". Would there be a possibility to add a master volume?
Also in my opinion the pedal sounds a bit too harsh, could there be a way to mod the pedal to get a sound with just a bit less high frequency?
pallas05
Postby halmark4 » 28 Nov 2012, 12:19
Hello! I've built the Les Lius to "Magichomeboy's" layout. I need more control over my volume, is it possible to change the value of one of the pots ( I use the recommended 100k Vol and 10k Boost) so that it can match my clean signal even at lower boost levels?
halmark4
Postby blue_tokai » 26 Dec 2012, 02:07
halmark4 wrote:Hello! I've built the Les Lius to "Magichomeboy's" layout. I need more control over my volume, is it possible to change the value of one of the pots ( I use the recommended 100k Vol and 10k Boost) so that it can match my clean signal even at lower boost levels?
Thought the recommended was 100K and 1K ???
blue_tokai
Postby andregarcia57 » 29 Jun 2016, 21:39
HELLO, staff found no information High Power Lovepedal Tweed Twin ... it would be a simple LES LIUS channel?
andregarcia57
Have thanks: 87 times
Postby nonost » 30 Nov 2019, 02:58
Hi. In the first page it is said the original circuit used one BAV99 diode. These diodes are "two in one". Each package contains two diodes.I've got some of them and they have a forward voltage around 0.580v. Since the suggested replacement is the 1n914 (1v Vf) I was wondering if the original is using two BAV99 instead of one. It's the only way the maths work.
Cheers!
nonost
Previous
Users browsing this forum: beniboy87, centraleuropean, jhergonz, orya01 and 9 guests
