Catalinbread - Formula No. 5  [traced]
Re: Catalinbread - Formula No. 5
Postby Gary_W » 31 Jan 2013, 11:57
Seiche wrote:I know what you mean, sometimes it is, sometimes it's not. The BS170P that the original SHO uses as a 180° pinout from the common BS170 many D.I.Y.ers substitute, for example. So same part number, different manufacturer can still have different pinouts, is what I meant.
More often than not the person doing the layout uses the pinout of the substitutes they have at hand, yet still lists the original part.
Thanks Seiche - I appreciate you taking the time to reply and I'll be especially careful of that in future :)
Gary_W
Postby H.A. » 23 Jul 2013, 02:14
Hello people.
This is my first post in this great forum, which I always read.
I just wanted to upload a PCB I made for Formula 5.
BOM, PCB and Layour on *.rar file.
PCB is verified, put it together with a COT50 from La Revolution Deux.
Pics:
Half-way through the wiring!
Etching
Layout preview of the PCB:
For this message the author H.A. has received thanks: 2
jt (23 Jul 2013, 07:50), telecaster (23 Jul 2013, 02:45)
H.A.
Have thanks: 2 times
Catalinbread - Formula 5f6
Postby mganzer » 14 Nov 2013, 15:56
Hi Guys; Anyone put the hands in one of that? someone knows what changes from formula n5?(aside from the obvious tone stack changes)?
MG
mganzer
Has thanked: 34 times
Have thanks: 27 times
Postby throni3fsb » 26 Nov 2013, 21:33
mutetourettes wrote:...
If anything, fed with humbuckers this pedal has too much gain. Any suggestions for reducing the gain?
Hello, schematic painters and signal tracers,
first, i wanna thank you for your good work. I built the Formula five last night and it worked immediatly. However, i wondered, why it clips a little bit hard with gain all down, when played hard. Especially with humbuckers, as you may have expierienced. With LTspice, i simulated it and changed the 62k input resistor to higher values, and changed it on my Formula 5 to 1000k. I've seen on the pictures on the first page of this thread, that it should be 620k instead of 62k, because the rings are blue red orange instead of blue red red. Could someone please verify this??
These days i will try to match the transistors. For that purpose, are there some recommended values, or is it ok as long as the transistors are in a similar region??
Greetings
Thomas
throni3fsb
Postby roseblood11 » 26 Nov 2013, 23:55
It's pretty obvious that it`s blue-red-orange, but that means "62k". 620k would be blue-red-yellow...
Does it sound better/closer to the original pedal with the 620k?
In another version of my vero layout I noted "C1 is 470pF, not 47pF" - but I don't remember, where that came from. Was it mentioned in the thread before?
roseblood11
Has thanked: 360 times
Have thanks: 326 times
Postby induction » 27 Nov 2013, 03:18
roseblood11 wrote:In another version of my vero layout I noted "C1 is 470pF, not 47pF" - but I don't remember, where that came from. Was it mentioned in the thread before?
Final answer is here with discussion throughout that page.
induction
Has thanked: 63 times
Have thanks: 133 times
Postby throni3fsb » 27 Nov 2013, 03:52
roseblood11 wrote:It's pretty obvious that it`s blue-red-orange, but that means "62k". 620k would be blue-red-yellow...
You are right. It is orange, but for some reason i had another factor in mind. so it is 62k.
I can't say that it is closer to the original. But for me, it works better because now i control the clipping only with the gain knob, not with my guitar volume knob anymore. I simply didn't like it, when the first clipping stage came to clip. Of course, the overall gain is lower with this modification. I don't know whether i will keep the mod or not, i will test it for a while.
Greetings
Thomas
throni3fsb
Postby mutetourettes » 12 Feb 2014, 16:56
So it seems there was a Mark II catalinbread formula no5 with (reportedly) some differences in circuit/components (and then a Mark iii, which was just a paint job supposedly) - does anyone have any idea about the differences?
(I'm not talking about the newer 5f6 by the way)
Mark
mutetourettes
Have thanks: 9 times
Postby Ice-9 » 13 Feb 2014, 22:40
Yeah roseblood the correct value is 470p It was my pedal originally and I made the mistake labelling it 47p, but that error was cleared up and the correct value was definitely 470p
For this message the author Ice-9 has received thanks:
roseblood11 (18 Aug 2015, 20:18)
Ice-9
Has thanked: 144 times
Have thanks: 370 times
Postby IvIark » 14 Feb 2014, 02:44
Thought I already posted this but must have missed it
For this message the author IvIark has received thanks:
beedotman (20 Feb 2014, 21:13)
IvIark
Has thanked: 668 times
Have thanks: 685 times
Re: cb formula 5f6
Postby matt239 » 25 Nov 2014, 21:31
+1
I have an original Formula 5, I'm curious what's different here. - Is it just the tone stack?
- Sounds nice.
matt239
Has thanked: 64 times
Have thanks: 5 times
Postby Motter » 18 Aug 2015, 07:47
I built this pedal with an extra footswitch for the 2M resistor (thanks IVIark!), but the box I have is drilled for four pots instead of three so I'm wondering what I can put in that fourth spot.
So far I'm thinking a voltage starve or a bass cut. What do you guys think would be more useful? Alternatively I could make that last pot into a boost pedal (sho or rangemaster), but I really like the built in boost effect of switching out the 2M.
Motter
Has thanked: 27 times
Have thanks: 112 times
Catalinbread 5F6 formula 55
Postby Nocentelli » 04 Feb 2017, 16:36
Anybody seen gutshots or (shock horror) own one? I'm tempted to buy one with a view to tracing and I'm interested in finding out if they are SMD
Nocentelli
Has thanked: 920 times
Have thanks: 871 times
Re: Catalinbread 5F6 formula 55
Postby roseblood11 » 10 Aug 2017, 02:43
BUMP
Would really like to see the Formula 55 traced...
roseblood11
Catalinbread Formula No. 55
Postby roseblood11 » 11 Aug 2017, 10:46
This pedal is incredible, I'd really like to see it traced!
https://www.youtube.com/watch?v=29NHfe8KQ3Q
roseblood11
Re: Catalinbread Formula No. 55
Postby POTL » 11 Aug 2017, 22:32
There is Formula №5
Presence control will look something like this
Although in an ideal it would be to see the scheme
https://s26.postimg.org/nd6u7z4ll/SC_1.png
POTL
Has thanked: 65 times
Have thanks: 65 times
Postby roseblood11 » 12 Aug 2017, 11:34
I built that years ago...
The Formula No.55 is a completely different circuit
roseblood11
Postby nicothyrael » 09 Oct 2017, 16:32
I'm making a Dirty little secret to practice until someone publish the schematic of this one.
I hope it will be soon, as I don't have one I can't help too much.
nicothyrael
Postby roseblood11 » 09 Oct 2017, 16:42
In most european countries it's possible to buy a pedal online and then to send it back without any cost. Off course, that's not a nice way...
roseblood11
Re: cb formula 5f6
Postby mr coffee » 25 Nov 2017, 17:55
Has anybody seen the insides ? The demo sounds pretty good.
mr coffee
mr coffee
Has thanked: 57 times
Have thanks: 12 times
Users browsing this forum: No registered users and 12 guests
