Catalinbread - Pareidolia Harmonic Mesmerizer  [traced]
Re: Catalinbread Pareidolia Harmonic Mesmerizer
Postby LaceSensor » 06 Jan 2012, 13:06
roseblood11 wrote:
LaceSensor wrote:any news on a layout / trace?
If someone (you?) draws a clear schematic, I'll draw a veroboard layout.
But maybe a pcb layout would fit in a 1590B enclosure...
Ive more chance of helping with the vero :shock:
LaceSensor
Has thanked: 45 times
Have thanks: 249 times
Postby coldcraft » 06 Jan 2012, 14:27
i can provide a PCB layout if someone makes me a clear schematic
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby gigelmargel » 06 Jan 2012, 22:06
Hello and thank you KindaFuzzy for your work!
On the schematic that you provide, both outputs of the TL072 (pins 1 and 7) go to "LED", but I can't see any LED in the schematic.
May I suppose that is the bypass LED, which is a pulsating one?
Best regards!
gigelmargel
Has thanked: 17 times
Have thanks: 15 times
Postby KindaFuzzy » 07 Jan 2012, 00:54
gigelmargel wrote:Hello and thank you KindaFuzzy for your work!
Best regards!
Oh, yeah they go to either one of the outside positive lugs of a two colour LED, and the center common negative end of that LED goes to the stomp switch, which grounds or ungrounds it to turn it on or off with the effect. You could probably do something similar with two regular LEDs with their negative ends tied together. The stock LED is green/orange but I had a green/red one that was pretty cool too.
KindaFuzzy
Has thanked: 106 times
Have thanks: 301 times
Postby gigelmargel » 07 Jan 2012, 10:04
Best regards!
Thank you very much KindaFuzzy!
Better to ask, because I understood wrong from the schematic.
Best regards!
gigelmargel
Postby hbo » 08 Jan 2012, 13:31
Thanks for the trace, KindaFuzzy.
I'm planning a vero layout for this one so I went ahead and drew up a schematic. Do let me know if I missed something.
For this message the author hbo has received thanks: 7
floris (12 Aug 2017, 21:57), Intripped (22 Sep 2013, 21:25), modman (06 Apr 2017, 09:47), Nocentelli (08 Jan 2012, 18:47), roseblood11 (08 Jan 2012, 17:45), tp801 (08 Jan 2012, 17:38), Zokk (11 Jan 2012, 23:28)
hbo
Has thanked: 31 times
Have thanks: 208 times
Postby roseblood11 » 08 Jan 2012, 17:52
Ah, the uncrowned king of the vero layout joins in! :P
Do you think that it will fit into a 1590b (=21 holes wide), maybe without a battery? Would be great...
Which program do you use to draw schematics?
roseblood11
Has thanked: 360 times
Have thanks: 326 times
Postby roseblood11 » 09 Jan 2012, 00:31
Which FET's are used in the circuit? KindaFuzzy wrote "2n5484" at the beginning of the thread, but "2n5485" a bit later... :?:
roseblood11
Postby KindaFuzzy » 09 Jan 2012, 01:23
5484's are in the original, I used 5485's on the breadboard so I must have put that on the schematic. I think they're almost the same anyways.
KindaFuzzy
Postby hbo » 11 Jan 2012, 13:31
roseblood11 wrote:Ah, the uncrowned king of the vero layout joins in! :P
I did the schematic in Eagle
As promised here's a vero layout. This one was surprisingly tough, but mostly because I tried to size it for a 1590B (which I think I managed). Hopefully there aren't any mistakes.
For this message the author hbo has received thanks: 17
culturejam (11 Jan 2012, 22:21), floris (12 Aug 2017, 21:57), G.G. (11 Jan 2012, 16:14), Intripped (22 Sep 2013, 21:27), Mich P (11 Jan 2012, 14:30), Nocentelli (11 Jan 2012, 16:44), roseblood11 (11 Jan 2012, 15:50), soggybag (01 Mar 2013, 17:12), tp801 (11 Jan 2012, 17:53), willc1968 (07 Mar 2012, 23:35) and 7 more users
hbo
Postby roseblood11 » 11 Jan 2012, 20:53
In the first post KindaFuzzy wrote that it's four 2n5484's and two 2n5457's...
roseblood11
Re: Catalinbread Pareidolia Harmonic Mesmerizer  [traced]
Postby hbo » 12 Jan 2012, 00:12
roseblood11 wrote:In the first post KindaFuzzy wrote that it's four 2n5484's and two 2n5457's...
Ah, didn't catch that.
I've updated the vero layout above, and here's an updated schematic as well.
hbo
Postby Mich P » 01 Feb 2012, 14:16
Is there someone 's done it ?
Mich P.
Mich P
Has thanked: 60 times
Have thanks: 17 times
Postby Nocentelli » 01 Feb 2012, 14:23
Mich P wrote:Is there someone 's done it ?
Mich P.
Still waiting for the bloody XR2206 chip. I ordered from musikding (only because they had all the parts in one place, so thought i'd save a bit on shipping) but they sent the rest of the order without the chip, which was "to follow"... still waiting. I've got the rest of the board built (lovely layout, thanks hbo!) JUST NEED THE CHIP.... Almost tempted to splash out on an eBay purchase just to get it done.
Mich P (01 Feb 2012, 21:47)
Nocentelli
Has thanked: 920 times
Have thanks: 871 times
Postby Pruttelherrie » 01 Feb 2012, 22:24
hbo wrote:I've updated the vero layout above, and here's an updated schematic as well.
Harold, are you willing to share the eagle schematic so I can have a try at designing a PCB? (Not having to draw the schematic myself saves me some time and averts possible errors!)
Iwan
Pruttelherrie
Has thanked: 53 times
Have thanks: 112 times
Postby roseblood11 » 01 Feb 2012, 23:30
Mich P.
I ordered a 2206 and the FET's the day KindaFuzzy started the thread,
but I have to admit that I'm just too lazy to start soldering... :P
roseblood11
Postby hbo » 02 Feb 2012, 00:15
Built it tonight. Works, and sounds nice too! I had to reorient the depth and rate pots. Rev. 3 is now verified.
For this message the author hbo has received thanks: 3
G.G. (02 Feb 2012, 00:24), modman (06 Apr 2017, 09:49), Nocentelli (02 Feb 2012, 00:18)
hbo
Postby Nocentelli » 02 Feb 2012, 00:15
roseblood11 wrote:I ordered a 2206
musikding?
Nocentelli
Postby roseblood11 » 02 Feb 2012, 00:18
no, a german e-bay seller, but too expensive
roseblood11
Postby hbo » 02 Feb 2012, 00:22
Iwan
Here you are. I didn't draw it with the intention of it ever being made into a PCB so let's hope I picked reasonable components packages.
Pruttelherrie (03 Feb 2012, 12:22)
hbo
PreviousNext
Users browsing this forum: No registered users and 10 guests
