Home-made Darlington problems
Postby commathe » 10 Dec 2013, 07:56
So I was playing around with slapping two transistors together to make a darlington and I have come across a really weird issue. For all transistors that I use, the darlington only behaves as it should when one or both transistors are put in "upside down".
For instance, if I am using two NPN transistors: When both their collectors are facing "upwards" and connected to the load/resitor that is between them and the power rail - they don't conduct. Nothing gets through. However, when I flip one of them round so the emitter is "upwards" it works. It doesn't matter which one. Actually it can be both! Why is this?
I thought I had labeled my transistors wrong, but I hadn't. I am running into this with all of my BJT transistors. I have double and triple checked datasheets to make sure I don't have the pinout mixed up. When I use a transistor individually though, it behaves like expected.
I should note that I came across this making a bazz fuss, so I am wondering if it has something to do with the collector-base diode in that design?
commathe
Have thanks: 8 times
Re: Home-made Darlington problems
Postby Rumbler » 08 Feb 2014, 16:44
I just finished my the 7-minutes fuzz (http://www.diyguitarpedals.com.au/shop/boms/7_Min_Fuzz_Schematic.pdf), which I think is based on the bazz fuss.
I did not have a Darlington and I combined two 2N2222A connecting the pinouts as you see here: https://imageshack.com/i/jwjwm6j. The fuzz works just fine.
I just double-checked the pinouts of my transistors, and I am sure I did not invert collector and emitter :lol:
I would control the connections to the other components. Maybe the mistake is there.
hope it helps.
Rumbler
Postby DrNomis » 08 Feb 2014, 17:04
commathe wrote:So I was playing around with slapping two transistors together to make a darlington and I have come across a really weird issue. For all transistors that I use, the darlington only behaves as it should when one or both transistors are put in "upside down".
That is weird, those NPN transistors should operate correctly when the emitters are pointing to circuit ground, two possibilities I can think of, could be a biasing issue, or, one or both of the transistors may be B-E short, but it's probably more likely a biasing issue, remember the Darlington Transistor configuration tends to produce a huge amount of current-gain if you're using two fairly high-gain transistors....... :hmmm:
DrNomis
Has thanked: 123 times
Have thanks: 405 times
Return to Transistors
