Sola Sound - Tonebender Mark II Professional  [schematic]
Re: Sola Sound - Tonebender Mark II Professional
Postby bato001 » 18 Jul 2014, 17:25
Electric Warrior wrote:I tried trimmers and decided I don't need any more options to mess up something that works perfectly fine the way it was designed. But then again I was lucky enough to score a handful of OC75s. All they need is a little swapping transistors around to make it behave nicely. Getting the voltages out of the range reported in vintage units is not easy with these. :mrgreen:
Lol. I hear ya brother. I always use whatever transistors I can get me grubby little paws on so i need those trimmers.
"Ever wondered how some of your favourite guitar players got their tone? Me too. Probably a good amp and lots of practice." Little Lord Electronics Homepage
bato001
Has thanked: 46 times
Have thanks: 58 times
Postby copachino » 18 Jul 2014, 18:01
LucifersTrip wrote:
copachino wrote:i tried a 33k first but q3 voltages was lower, so i used 47k(stock mkII) and q3 got about 8.5V now,
This is with the 2.2K on Q3? what do you get with the 8.2K back there? you should get around 7.5-8.5V
did Small Bear instructions tell you 4.5V?
with 8.2k i was getting like -5V, and sounds fine, but fuzz was light, it didnt had that beast on it, so i was changing untill i got the voltage of 7.5v on 2.2k, also its seems that HFE its fine, or at least to me are quite good, q1, its 65, q2: 95, and q3: 120
copachino
Have thanks: 6 times
Postby jalmonsalmon » 18 Jul 2014, 18:51
Hehee
I know with my mkII's I have one with OC75s and the other has OC84s - the 84s are so forgiving and those bias up great with no issues, but for my OC75s I had to use a trimmer on Q2c to get the voltages right with the 8.2k resistor on Q3c and swapping them around like EW says. Was a pain to get it to sound how I like it but that OC75 pedal is a beast! OC84 version to me seems smoother but both are great!
jalmonsalmon
Has thanked: 82 times
Have thanks: 24 times
Postby Electric Warrior » 18 Jul 2014, 19:04
That's a huge spread of hfes. When I have measurements at hand I just pick three transistors that are in roughly the same ballpark and take it from there.
Electric Warrior
Has thanked: 21 times
Have thanks: 89 times
Postby copachino » 18 Jul 2014, 19:11
as fas as i know thos hfes area near the suppossed of solasound originals
copachino
Postby Electric Warrior » 18 Jul 2014, 19:38
jalmonsalmon wrote:Hehee
OC75s usually aren't that unforgiving. But you have one of those small bear sets with the huge spread of gains as well... With such a limited choice of transistors a trim pot sure can make your life easier.
I once got three random Valvo AC125s in an auction with lots of other stuff. They worked alright. This is what I ended up with:
Q1: hfe: 83; 404µA leakage
Q2: hfe: 65; 299µA leakage
Q3: hfe: 80; 388µA leakage
I was quite surprised to see I picked the lowest gain one for Q2. In the past I've ended up with the highest gain one in that spot frequently. But it's hard to generalize anyway. You mustn't take only hfe into account. Leakage plays a role as well, so you have six variables to play with. Rather complicated, so I just use whatever sounds good.
According to whom? There are not so many hfe readings of vintage units available on the internet. David Main of D*A*M fame once posted these:
Q1 - 174
Q2 - 208
Q3 - 194
But that doesn't tell us much without the leakage readings - other than the OC75s in that particular unit were rather high gain. But I feel that doesn't make all that much of a difference, anyway. It's not about absolute hfe readings but more about how hfes and leakages interact with each other. And there's more than one way that works, I can assure you that.
Electric Warrior
Postby copachino » 18 Jul 2014, 20:35
i was reading and telling what i hace read on fuzzcentral, and also some other pages, but im not 100% sure since i dont have the vintage unit
copachino
Postby copachino » 18 Jul 2014, 20:38
Q1 - 174
Q2 - 208
Q3 - 194
i know things will go better with a cupple of OC75s trannies, but these are like the most rare things to find, if someone want to sell me a kit it would be amazing
copachino
Postby Electric Warrior » 18 Jul 2014, 21:39
copachino wrote:i was reading and telling what i hace read on fuzzcentral, and also some other pages, but im not 100% sure since i dont have the vintage unit
I believe fuzzcentral recommends something like 70-70-100 and getting Q3C down to -4.5V.
It's not a reliable source for MKII info. The OC81D circuit on top of the page is correct. The other two vintage circuits both have issues.
I have a vintage unit, but I'm not willing to unsolder the transistors. I can get in the right tonal ballpark without knowing the exact hfes or leakages.
copachino wrote:i know things will go better with a cupple of OC75s trannies, but these are like the most rare things to find, if someone want to sell me a kit it would be amazing
They're not all that rare, really. But most you'll find on ebay are overpriced.
OC75s make things easy, but other transistors can work as well. I believe leakage is the key. I wish there was some affordable, readily available new production alternative that I could recommend…
I was lucky with the Valvo AC125s I mentioned. I tried to get more, but I only ended up with some Philips that don't leak quite enough... oh well. I'll find a use for them. Maybe you can try Tungsrams? They're cheap, available and some leak a lot I hear. No idea how they sound, though.
Electric Warrior
Postby copachino » 18 Jul 2014, 23:06
how about this one?? http://www.ebay.com/itm/OC75-Germanium- ... 19d65bce77 do you think they could work?? they are really expensive, my friend, as you have a vintage unit its posible to get some voltages reading?? just to be sure
copachino
Postby copachino » 18 Jul 2014, 23:30
this are mullard seems something good
http://www.ebay.com/itm/GERMANIUM-Trans ... 3255&rt=nc
copachino
Postby Electric Warrior » 19 Jul 2014, 00:03
They're probably great. But way too expensive. Personally I wouldn't pay more than $4 for an OC75..
Electric Warrior
Postby copachino » 19 Jul 2014, 00:28
Electric Warrior wrote:They're probably great. But way too expensive. Personally I wouldn't pay more than $4 for an OC75..
i knñow they are really expensive, but i cant find anywhere else to sell them for less
copachino
Postby copachino » 19 Jul 2014, 07:21
i have leave everything stock, Q1 10k and -8.2V. Q2 47K and -0.32v and Q3 8.2k and -6.45V power supply at -9.36v, its 12:20 am so i cant tray it out but tomorow i will post the results of leaving stock everything, if i could get the right spot on voltages could it be fine, also i have seen taht there 2 kits on small bear that are OC75 mullards, but without the gain spot on it, but the are pretty cool i will try buy the monday if no-one else does first.
copachino
Postby Masuto » 11 Aug 2014, 05:59
I recently got out the only smallbear set i ever bought, some texas instruments 2g308 on q1, 2g303 on q2, and 2g308 again on q3..this set costed more than the oc75 set he was offering at the time (more than one year ago). After a few successful builds, i must say that set sounds great, even though i didnt comply with the resistor value he sent me on paper, and kept it stock.and guess what, it sounds very much like the oc75 builds.
If youre a newbie, or have unsuccessful builds, my advice is to buy a tested set, and use stock values.. Or smallbears attached handbill that suits their measurements for the set..
Then experiment using it as a template against other builds.
I am still deep in the transistor swapping swamp with my oc70, oc74, oc77, oc79 valvos..bear with me.
Talking about expensive stuff, I lost an auction for 5 yellow jacket oc44s: i think it ended at round 50 pounds.
Masuto
Has thanked: 42 times
Have thanks: 5 times
Postby boblob » 11 Aug 2014, 22:23
I can vouch for the cheap and readily available Tungsram AC125s - really decent. Closer to OC75s than OC84s, just a touch noisier than either with the Attack at max. I find they don't need to be quite as leaky as EW's Valvos. Putting the lowest leakage in Q2 helps it to bias properly with the stock 47k resistor. I have a bag of Philips AC125s that are more in the 3-500uA range that I couldn't really use - maybe I should dig 'em out and have another go.
I did get a set of Philips OC75s off SmallBear about 3 years back. They were well matched and sounded great, no messing about required. Gains were 80-100 and all leaked about 350uA IIRC.
The Sola Sound OC84 reissue that I have has 15nF caps in place of the 10s to compensate for drift. That's pretty important - sounds much more like a vintage unit if you do that (more mids, a little smoother up top, and just generally better). Up to 22nF on the output cap still sounds good with the Tungsrams.
Another thing to note about the Tungsrams - some are marked "HM" on the top and on the packet. These are consistently lower leakage and gain than ones that aren't marked "HM" and work well in the mk ii. I've had a look at the Tungsram catalogue, but I don't see any mention of that.
For this message the author boblob has received thanks:
Masuto (12 Aug 2014, 06:41)
boblob
Have thanks: 10 times
Postby boblob » 11 Aug 2014, 22:37
copachino wrote:this are mullard seems something good
A while back that same guy was selling an assorted lot of OC types for something silly like £200 and listed 'em as "Mullard/Valvo NOS". A closer look revealed a good number to be new production DSi OC81Ds, and IIRC a few similar OC44s. A mate of mine nearly fell for it, so I pulled him up on it and said it was a little dishonest to list them as "Mullard/Valvo", asked him to consider changing the listing and knocking the price down accordingly. He gave me a load of shite about them "being made on the old 60s die lot" and wouldn't hear of it...
boblob
Postby Masuto » 12 Aug 2014, 08:09
I was listening to Led Zep I after ages, having bought the new remaster the other day.. at 00.30 before the end of You Shook Me you can hear the sustained note, having a pretty bad oscillation. Yes, could be anything.. but got me wonderin.. most of my tone benders oscillate in one way or another.. even subtly.. What do you pros say? Also, on You Shook Me, to my ears the main riff (two guitars? With vocal underneath? Some breathy stuff goin on but could be the hissy fuzz) from hell, sounds a lot like a (Ronno harp like half coked wah tone) mk i!
Can you guys dig it?
Masuto
Postby Nocentelli » 12 Aug 2014, 11:02
Have you read the "Page fuzz" thread at the D*A*M forum? There is masses of discussion of page's fuzz tones, You Shook Me features heavily.
Nocentelli
Has thanked: 918 times
Have thanks: 864 times
Postby Electric Warrior » 12 Aug 2014, 12:49
boblob wrote:The Sola Sound OC84 reissue that I have has 15nF caps in place of the 10s to compensate for drift. That's pretty important - sounds much more like a vintage unit if you do that (more mids, a little smoother up top, and just generally better). Up to 22nF on the output cap still sounds good with the Tungsrams.
I don't think that Dave uses the 15nFs to compensate for anything. Many vintage units had 15nFs, his own Vox included. He likes that sound a lot!
[youtube]ohT4Chsa8hs[/youtube]
Read the whole story here: http://www.stompboxes.co.uk/Wifey.html
Electric Warrior
PreviousNext
cron
