Code: Select all
which gives you:
Please, support freestompboxes.org on Patreon for just 1 pcb per year!
Has thanked: 3379 times
Have thanks: 639 times
Code: Select all
Code: Select all
Hope this helps! :D
Limadito
[youtube]http://www.youtube.com/watch?v=_li_d_YviZ4&list=RD_li_d_YviZ4&index=1[/youtube]
Duckman
Has thanked: 369 times
Have thanks: 143 times
Duckman
Limadito
Code: Select all
Warning
Code: Select all
Warning
Code: Select all
/* Custom styles
.video-wrapper {
   width: 640px;
   max-width: auto;
.video-container {
   position: relative;
   padding-bottom: 56.25%;
   padding-top: 30px;
   height: 0;
   overflow: hidden;
   position: absolute;
   top: 0;
   left: 0;
   width: 100%;
   height: 100%;
The bbCode in use is
Code: Select all
And HTML Replacement is
Code: Select all
<div class="video-wrapper">
<div class="video-container">
</div>
</div>
Limadito
Postby PegasusOne » 12 Sep 2019, 14:48
Embed videos & playlists
1. On a computer, go to the YouTube video you want to embed.
2. Under the video, click SHARE .
3. Click Embed.
4. From the box that appears, copy the HTML code.
5. Paste the code into your blog or website HTML.
PegasusOne
Return to Software Room
Users browsing this forum: MSN [Bot] and 1 guest
