Darkglass - Microtubes B3K / B7K  [traced]
Silver Blues
my favorite amplifier: Genz-Benz Shuttle 3.0
Completed builds: Many, at this point...
Has thanked: 23 times
Been thanked: 24 times
Post by Silver Blues »
Still might be cool. One can never have too many good overdrives :mrgreen: It's odd though, the files are labelled "B2K" but everywhere else says "B3K" and I can't find any information at all about the B2K...
lars-musik
Has thanked: 28 times
Been thanked: 26 times
Post by lars-musik »
has anybody out there a schematic for the Darkglass B3K? That would be greatly appreciated! Thanks!
Darkglass B3K gut shot
Cub
Has thanked: 102 times
Been thanked: 118 times
Post by Cub »
No schematic, but I assume your goal is to build a clone ? Then you can save yourself a lot of time and order a kit with the PCB and parts of the GUMA-Drive from http://schalltechnik04.de/. Knobs and an enclosure are optional, either drilled and bare or completely drilled, painted and labelled. 8)
lars-musik
Hi Cub,
yes, thanks. I knew that kit. But indeed I'd need a schematic to do my own. Preferably in a 1590a and without the relay bypass.
I found the Vintage model and guess I am just as happy with this one.
Cheers!
Silver Blues
Going by what I had to go through with the VMT, this is going to be literally impossible to fit in a 1590A. I have photos of the GUMA boards but I'm not sure a good trace could be done with them, as much as I'd love to know.
Cub
Post by Cub »
With a couple of layers of boards with SMD components, it should theoretically be possible. Practically, that's a different story. :lol:
Besides, a 1590A with side-mounted jacks isn't much less wide than a 1590B end-mounted jacks.
miguelmoita
Been thanked: 39 times
Post by miguelmoita »
Here is the schematic of the B3k. Very similar to the VMT that is already available on the forum. I did not test it yet, but I test the VMT and sounds awesome. So, I am confident for this one too.
I will make a tone transfer, test it and the post it here in a couple weeks.
Cheers
nezvers
Completed builds: Bajaman pickup preamp v.1
Post by nezvers »
Sorry for my lack of knowledge but I don't see the source for VD and VDD which I assume are VR / (1/2Vcc).
olyaneko
Has thanked: 29 times
Been thanked: 5 times
Post by olyaneko »
probably that's how it will be :roll:
miguelmoita
Yes, you are right. I forgot!
That's the right place to put the VDD.
I just finished mine.
Sounds awesome!! I did not had the opportunity to compare with the original yet. But I am very satisfied with the sound of it. Its brutal like a true Darkglass.
I attached some photos. Just needs the decals now.
i just saw some errors and missing values in the schematic.
I used different JFETs than the J201 that I put in the schematic. I used the MMBFJ201. They are SMD, but I order from Musikding some little adapters that coverts to through hole footprint to make the tone transfer process easier.
I did not tried the J201 so I do not know if it sounds different or not.
I forgot the values for the Pots. Level: A100k; Blend: B100k. Drive: C100k
D1 and D2 I used 1N4148.
And I think that is all.
Cheers
olyaneko
Post by olyaneko »
please, and can you give a PCB file for this circuit ?, ... mmm you can just take a picture-photo, I'll rewrite it later (for example in Sprint Layout, i can draw a little in this program), please :oops: ...
Silver Blues
The MMBFJ201 are just J201, but in an SMD format. A great many people are using them as substitutes for the TO-92 J201s because they are far more consistent and easier to find.
miguelmoita
ok Silver Blues. That's what I thought.
Actually I had some troubles with the inconcesty of the J201 in the past. That is why I did not think twice to use the MMBFJ201.
Olyaneko just give me a few days to organize the file. The drawing is a bit confusing because I used two PCBs (one on top of the other) to fit it on a 125B using PCB mount Pots. I think it will arise some doubts the way it is.
fersynes
Post by fersynes »
Could you please post the PCB and layout?
olyaneko
Post by olyaneko »
mmm, is that you to me ? :roll:, i still do not have them :oops: ...
miguelmoita
Hello all,
Here it is! :D
Sorry about the delay. I had a lot of work this week.
Just a few hints. The VDD connects to the lug 3 of the level pot and lug 2 and 1 of the Drive pot. G2 is just another ground terminal, ignore it if you want.
If you have any questions just let me know.
I had the opportunity to experiment with different basses and amps during this week and I notice some inconsistency with passive and active basses. Passive sounds a lot better. I also mount the VMT and is way more consistent on this. Sooo, now I am not sure that everything is ok. I am thinking to make a new one to figure it out, but it will take a while. So, it will be very nice that you try it and let me know your opinions.
Miguel
B3K.pdf
(137.85 KiB) Downloaded 1565 times
olyaneko
Post by olyaneko »
nyaaaa, a tremendous thank you :oops: ,...mmm, and the red bar in the drawing is a jumper ?, right ? :oops: :oops: ...
...mmm, and I'm on the drawing where to connect the toggle switch "Attack" is not found :oops: :oops: ,...oops, i'm sorry, it turns out "Boost" was named, it's me inattentive :oops: :oops: :oops: ...
fersynes
Post by fersynes »
Thank you so much! I Will try it and tell what happen with my active bass
miguelmoita
You're welcome guys! :)
Yes olyaneko, the red bar is a jumper and Boost switch is the Attack.
One more thing that I forgot to warn. Lug 2 of Level pot connects to lug 3 of Blend pot as you can see in the schematic.
Go for it fersynes. :) I'll be waiting your feedback.
fersynes
Post by fersynes »
Wells I built ir and the controls are working but there is a constant sound thicking (mybe a shortcut) like "tuktuktuktuktuk" that caries with the drive pot and Boost Switch. Still can't figure out what's the problem but Will try to debug it later or built a new one. I cheked all the wire conections mentioned and are right. Will tell if i make it. Sorry for my English. Cheers
