Fortin Zuul  [traced]
Re: Fortin Zuul
Postby plush » 21 Apr 2019, 21:37
Manfred wrote:IMO to cause confusion or maybe to make a unpolarized capacitor in the case of two electrolytes capacitors or tantals
Here the equivalent circuit:
Or maybe even to achieve some visuals, who knows, some people prefer pretty pcbs that are somewhat symmetrical )
plush
Has thanked: 32 times
Have thanks: 91 times
Re: Fortin Zuul
Postby modman » 24 Apr 2019, 14:35
So sorry this thread got locked by accident while moving it. My bad.
Has thanked: 3451 times
Have thanks: 660 times
Re: Fortin Zuul
Postby plush » 03 May 2019, 23:01
guiddruid wrote:Build docs uploaded now; https://www.pedalpcb.com/docs/PedalPCB-Muzzle.pdf
Also OA3 needs + and - to be swapped.
plush
Re: Fortin Zuul  [traced]
Postby bugg » 05 May 2019, 16:20
Just to clarify... the pin numbers were correct, the graphical symbol just needed to be updated. It's corrected now.
The C7 / R7 / C8 junction really confuses the hell out of me... They aren't polarized caps so polarity isn't the issue.
Sometimes in mass production it's more economical to use two of the same part rather than two different parts. However, it's odd that the resistor is in the middle of the network... :hmmm:
Would there be any benefit to reducing the amount of AC voltage drop across each of the individual capacitors?
For this message the author bugg has received thanks:
guiddruid (06 May 2019, 17:44)
bugg
Has thanked: 39 times
Have thanks: 237 times
Re: Fortin Zuul
Postby guiddruid » 06 May 2019, 17:39
C7/R7/C8 - 99% this is just a cut & paste mistake when adding an emitter-follower input buffer to the Marshall circuit J0K3RX linked to. The resistor between the two capacitors is functionally equivalent to what Manfred drew - order doesn't make any difference. Other than polarised caps (not the case here, and a bit of a hacky circuit anyway), the only other reason I can think of to do this (again, not in this context) would be to protect against short-circuit failures. So, I'd suggest 99% chance it's a cut & paste mistake by Fortin. 1% chance he incorrectly thought this did something useful.
I suspect the differences in some of the capacitor values between the Marshall & PedalPCB schematics may be down to measurement accuracy (bugg, does this seem likely?), though the differences look too small to make any audible difference. Adding an isolation transformer to the key input would be a nice improvement, along with a buffered key pass-through.
The Marshall circuit likely started from the app note here, but is in no way a simple copy; http://www.thatcorp.com/datashts/dn100.pdf
guiddruid
Have thanks: 5 times
Re: Fortin Zuul
Postby bmxguitarsbmx » 07 May 2019, 03:48
BTW, the Marshall jcm800kk schematic is not 100% of the amp I had in my shop. Which, usually is to be expected.
bmxguitarsbmx
Has thanked: 301 times
Have thanks: 94 times
Re: Fortin Zuul
Postby plush » 07 May 2019, 14:29
guiddruid wrote: though the differences look too small to make any audible difference.
Afaik, VCA's have pretty low input impedance, lowering the cap value will affect the signal.
Can't tell if their RMS detector is the same, though. Will have to test with 4301-s. Sad thing they are discontinued.
Welp, the key pass-through is already buffered. And there are no affordable signal transformers with wide dynamic range. Your idea is good though.
plush
Re: Fortin Zuul
Postby psychodave » 13 May 2019, 04:53
I have the Zuul pedal and mine has issues. While using the key input in the loop, when I turn the pedal off it causes a really bad buzz. The way I was able to correct the issue was to remove the ground on the key input cable. Clearly there is an issue with it. Any thoughts on how to fix it?
Also, the pedal adds quite a bit of drive when turning it on... it’s far from transparent. I’m not sure if this is due to the issue above or not. Just figured I’d mention it.
psychodave
Re: Fortin Zuul
Postby guiddruid » 13 May 2019, 08:32
Try turning the gate control to minimum & playing softly with the pedal on - I suspect you'll hear the buzz then too, which is caused by a ground loop.
Because the key input is not isolated, you're connecting the ground at very different points in your signal chain together, which can cause the problem you've found. I used an isolated buffer to drive the key input to fix this.
I have not noticed a big difference in the sound between on vs off, though it is just noticeable. May depend what you've got connected.
Plush - if you just isolated the key input, you could probably get away without an amazing hifi transformer, although you may not be able to buffer a key output very easily - http://www.hexeguitar.com/diy/gear/buffsplit
guiddruid
Re: Fortin Zuul
Postby plush » 13 May 2019, 13:30
guiddruid wrote:Plush - if you just isolated the key input, you could probably get away without an amazing hifi transformer, although you may not be able to buffer a key output very easily - http://www.hexeguitar.com/diy/gear/buffsplit
Sorry, I don't get what you ary trying to tell me.
If you simply throw in some low quality transformer, it will have quite noticeable corner frequencies, leading to poor performance, compared to non-isolated key input.
plush
Re: Fortin Zuul
Postby caspercody » 13 May 2019, 15:24
I built the Zuul pedal from Pedal PCB, and you DO NOT connect the key to ground...
For this message the author caspercody has received thanks: 2
bmxguitarsbmx (10 Jul 2019, 05:38), guiddruid (13 May 2019, 21:16)
caspercody
Has thanked: 31 times
Have thanks: 50 times
Re: Fortin Zuul
Postby plush » 13 May 2019, 15:53
caspercody wrote:I built the Zuul pedal from Pedal PCB, and you DO NOT connect the key to ground...
This :thumbsup
There's really no need for key's ground connection, if the rest of the circuit is already referenced.
plush
Re: Fortin Zuul
Postby guiddruid » 13 May 2019, 21:13
Not connecting the ground makes sense. The key input on the Zuul does have a ground connection though.
Something like this might be a better approach to producing a buffered key pass-through; https://www.ti.com/lit/an/sloa143/sloa143.pdf
Then again, perhaps just making the key input really high impedance & not connecting the grounds would be enough?
guiddruid
Re: Fortin Zuul
Postby caspercody » 13 May 2019, 21:23
Here is the reply from PedalPCB when I built mine:
The three pads near the bottom are for setting the threshold range. You can either use a mini slide switch or a triple pin header with a jumper.
https://www.taydaelectronics.com/electr ... 24vdc.html
The two pads near pin 1 of the THAT are for the Key jack.
You'll need a switching 1/4" jack for that. The pad on the left goes to the Tip lug, the pad on the right goes to the Switched Tip lug. (not to be confused with the Sleeve or Ring)
https://www.taydaelectronics.com/6-35mm ... -jack.html
All other wiring is common to the other projects.
caspercody
Re: Fortin Zuul
Postby psychodave » 13 May 2019, 23:43
Here is a video I made of the hum. The hum was in the ungated signal as well. Once I removed the ground on the key input, the hum was gone.
https://youtu.be/RBKB_NxgLQI
psychodave
Re: Fortin Zuul
Postby equinox » 09 Jul 2019, 13:21
Dave
Try it with a different amp (other than the Cameron) for shits and giggles and see if it follows the amp or not.
Eq
equinox
Have thanks: 2 times
Re: Fortin Zuul
Postby dlazzarini » 26 Jul 2019, 01:31
I built the same pedal from pedal pcb. I received an updated board that did have a ground pad for the key input. I did use it but now I’m wondering. The pedal is awesome and works fantastic but one minor little thing I noticed is that when I’m not playing and the gate is shut, if I lightly rake over the treble strings I can very faintly hear it bleed through to the amp. No unwanted hiss or hum, just the strings faintly. When I play the gate kicks open and works as it’s supposed. Could this slight bleed be ground related?
dlazzarini
Re: Fortin Zuul
Postby guiddruid » 26 Jul 2019, 20:52
The "gate" is not on/off. As the level of the key signal reduces, the input->output gain reduces more quickly. For example, key halves in amplitude results in gain dropping by 4. (not actual numbers, just for example).
If you turn the control knob up you should hear the "bleed through" get quieter & eventually disappear.
I don't think the ground will make any difference - it'll either cause a nasty hum (when the pedal is bypassed) or it won't.
guiddruid
Re: Fortin Zuul
Postby Silverhair » 09 Aug 2019, 17:55
where do you get the THAT4301 IC?, I'm located in Mexico, but I buy mostly from the US
Silverhair
Re: Fortin Zuul
Postby caspercody » 10 Aug 2019, 03:14
I bought mine from PedelPCB
Silverhair (12 Aug 2019, 19:22)
caspercody
PreviousNext
Users browsing this forum: cajitastompboxes, squirrels, taterwalt and 6 guests
