Greer Lightspeed
horselover_fat
Post by horselover_fat »
I've searched the Net, and can't find any info about what it is based on.
I know Greer, and he'll never have an original idea, so i *know* it's based
on something. I suspect he's pulled a JHS and based it on something from
Runoffgroove.
If anyone has traced it, or knows otherwise, all thanks.
caspercody
Has thanked: 34 times
Been thanked: 48 times
Post by caspercody »
I have no information on this, but wanted to bump this. Also if you know Greer maybe ask him about it?
horselover_fat
I no longer live in Athens, so I'm unable to ask him. Even if I could,
getting an honest from him about much of anything is next to impossible.
He's well known in Athens for being a bit challenged in the honesty department.
He told me with a straight face, looking me in the eye, that the Ghetto Stomp
was an original design all his own.
Fredenando
Has thanked: 453 times
Been thanked: 90 times
Post by Fredenando »
I have found this on a japanese web:
horselover_fat
For the first five or six years he was building pedals, he didn't goop anything.
His gooping of pedals tells me he has something to hide now.
RiGLEY
Post by RiGLEY »
Any info?
FiveseveN
Has thanked: 215 times
Been thanked: 116 times
Post by FiveseveN »
Previous thread: viewtopic.php?f=33&t=24982&p=243495
Put me down for $10 on Tubescreamer variant.
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
*BUMP*
I'd really like to see a schematic for this one. Maybe it's just a variation of the tube screamer, but a very good one.
https://www.greeramps.com/products/lightspeed
287m
Has thanked: 481 times
Been thanked: 74 times
Post by 287m »
roseblood11 wrote:*BUMP*
https://www.pedalpcb.com/product/mach1od
easy to build in 1590a. hehe
vtguedes
Post by vtguedes »
Pedal PCB has it traced. It is a timmy with fixed eq controls, assymetrical clipping with 5 diodes (3+2) back to back and a simple treble roll-off for tone control at the end.
Build docs here: https://www.pedalpcb.com/product/mach1od/
I have done a vero layout from PedalPCB's schematic, it is verified and sounds pretty much like the lightspeed.
https://drive.google.com/open?id=10QOkU ... mZTLnIP-9D
ppluis0
Has thanked: 127 times
Been thanked: 299 times
Post by ppluis0 »
HEY !!!
Why invest in an expensive op amp ($ 4.30) for this application ?
Any dual operational at fraction of cost can be used in this overdrive without change in performance... :roll:
vtguedes
Post by vtguedes »
Oh, I've tested my build with 4558, TL072, TL082 and the OPA. All sounded the same to my ears, I just wrote in the layout the same part that was in the schematic.
roseblood11
Hiss might be a bit lower, but...
Things are boring these days. PedalPCB has everything already...
FeVeR2112
Has thanked: 47 times
Been thanked: 60 times
Post by FeVeR2112 »
roseblood11 wrote:Things are boring these days. PedalPCB has everything already...
... and is that BUGGing you?
Ben N
my favorite amplifier: Ampeg J12D Jet
Has thanked: 198 times
Been thanked: 54 times
Post by Ben N »
Is that just hot glue? Even the goop is unimpressive.
Huff and Doback
Post by Huff and Doback »
Is it possible to build the Timmy with the Lightspeed diode arrangement as a switching option? I have both pedals and prefer the Lightspeed with single coils and the Timmy with humbuckers.
roseblood11
Sure. Leave enough space for a rotary switch for various clipping arrangements. Or use a simple dpdt switch for two sounds. A dpdt on-on-on can be used for three sounds: One side of each diode combo is hardwired to the circuit, the other sides go to lugs 1, 4, 6 respectively. There's many combinations that sound good in this circuit. I tried germanium diodes, LED's an Mosfet Transistors, and all were useful.
https://musikding.rocks/userImages/a6/361-a695797e.jpg
vtguedes
Post by vtguedes »
Be aware that, besides the clipping options, the Lightspeed is a Timmy with fixed bass and treble controls AND a treble roll-off after the 2nd op amp. That might make some of the difference between single coils and humbuckers you said.
Anyway, you could make a regular lightspeed and put a spdt on-on switch to turn the "lightspeed" tone pot on and off.
FeVeR2112
Post by FeVeR2112 »
I built it but have a squeal happening when drive and loudness reach a certain point in relation to each other - i.e.: when the drive is full up, the loudness will cause squeal when about half way. the same happens when the drive is lower but the loudness is higher. Anyone else encounter this?
HamishR
Been thanked: 46 times
Post by HamishR »
While I'm not a huge fan of the Timmy it's still a beloved pedal of many for good reason. The Lightspeed seems to be a way of taking a revered pedal and making it less useful. I built one to see what the fuss was about and found it altogether underwhelming. I'd take a Timmy over the Lightspeed any day.
