More volume on BBE Green Screamer
Postby javimart1212 » 16 Feb 2020, 10:20
I love this pedal as a clean boost, all that mid hump with no clipping cuts through the mix, but how could I get more volume on this great TS clone?
javimart1212
Re: More volume on BBE Green Screamer
Postby Manfred » 16 Feb 2020, 10:36
Make the clipping diodes switchable, then you can get more undistorted signal when they are switched off.
Has thanked: 1105 times
Have thanks: 721 times
Postby EddieTavares » 17 Feb 2020, 11:59
You can increase a little by increasing VR3 to 100k or 1M but if you want much more volume you have to implement one booster between C9 and VR3.
EddieTavares
Have thanks: 17 times
Return to Pimp-My-Cheap-Pedal
